Gary is a serious tape head - in the background is an Ampex 102 with Aria Electronics. I also have to express my thanks to many forum members here who had nice things to say re the Doshi Tape preamplifier.
I want to personally Thank Nick for his help with the Doshi Pre. It has elevated my system to yet another level.
His tape pre is the real deal & anyone considering should have a serious listen. I could not believe the difference it makes & it's not even burned in.
All the accolades to Nick are deserving.
Dre, Thank You, we need to get together sometime soon.
I agree. Unfortunately, the last few time I've been up in your area visiting in-laws, my time has been limited. I'll try to fix that on one of my trips this year. Fingers crossed...
BTW: I see you pulled the platform among other things. Looking good.
Could someone describe how you routed the cables with the A820?
I presume the audio signal is taken directly from the repro head bypassing the repro head preamp, repro amp, and line amp.
How would the external repro head electronics affect the features/flexibility/programming of the A820
Thanks.
This particular 820 had been previously modified for use with a external preamplifier and had a balanced cable brought out to a pair of RCA connectors on the bulkhead. I removed the RCA's and installed XLR's (separating the -ve from ground) and then we ran a short 3 ft jumper to the outboard preamp. An intriguing thought is the improvement brought about by removing the switch and running dedicated cable to the outboard electronics. My guess would be that it may not be worth the loss of utility provided by the switch.
As far as the unit goes - nothing else was changed with respect to the internal record electronics and related functionality. (to my knowledge)
I don't know if anyone noticed the diffusor in the back with the pink Floyd poster cut into it - glad I saw it sober cause it may have been too much otherwise.
first thought as I got into my car on the return trip - gotta make myself one of those !!
