Hi Myles,
Well, I have a specific plan for best and cleanest power. The main breaker panel in our house has a main circuit breaker of 3x 80A - 240V. I have installed a split in the main breaker panel after the main breaker and the meter. One part of that split leads to the rest of the contents in the breaker panel which include all the circuit breakers for the electricity to the entire property. On the other end of the split I have installed an in-wall cable with a solid core copper conductor size of 16 square millimeters. This cable is drawn around the outside of our house to where our living room is. Here the cable is terminated in a split with three outputs. Then from each output a simar cable leads to the back wall of each hifi system where each cable is terminated in a three phase Isoclean Zero Ohms breaker panel. In these breaker panels each component in the system has its seperate 32A circuit breaker. By each component I mean CD-player combination, SACD-player combination, DVD-Audio-player combination, Music Server combination, Turntable, Phono Preamplifier, Preamplifier and each monoblock. Short (2 meters) dedicated lines are installed from each circuit breaker to its single 32A Phillip Hauge wall outlet. For the amplifier circuits, the cable used between the circuit breakers and the wall oulets are the same cables used before the Isoclean Zero Ohms breaker panels with 16 square millimeters solid core copper conductors. For the other circuits, the cable used between the circuit breakers and the wall oullets are a special in-wall silver conductor cable made by Oyaide with a special double sheilding. A seperate power conditioner is plugged into the wall oulet on all non-amplifier circuits. So every non-amplifier component is plugged into its dedicated power conditioner.
So all three systems will share the same power supply since its not likely more than tops two systems will be playing at the same time.
A separate grounding solution from ATI Tectoniks similar to what Brian Ackerman of Audio Imports have installed will be installed while building the studio.
In the livingroom system Finite Elemente Emperor Active component stands will be used for all components.
In the Solid State system HRS MXR-M3X will be used for all components.
In the Tube system a mix of component stands and isolation products from Symposium Acoustics, Silent Running Audio, Copulare, Rix Rax, Critical Mass, Grand Prix Audio and AudioAV will be used.
As for signal carrying cables and power cords, these are not chosen yet. After everything else is installed I will start tryouts for cables. My initial thoughts run towards a mix of Siltech and Kharma in the living room system, a mix of Transparent Audio and MIT for the solid state system and a mix of Nordost and Purist Audio Design in the tube based system. However I will use a lot of time to find dedicated power and signal carrying cables for every component. I also hope to find somewhere to use my Kimber Black Pearls.
BTW, I have no kids which provides me with some extra time and $$$.
Thanks,
Roysen
