Not every amp is going to be the best match for every speaker no matter how expensive the amp is.
I guess i would classify this as another amplifier targeted @ the 93db/w/m/ 8 ohm speaker crowd ....
I listened to it playing a little too loud for my taste with speakers having 89 dB/W and 2.4 ohm low peaks and it sounded great. It was easily the best "Crime of the Century" I have ever listened to.
Yes, I do not like its price ...
in the interests of full disclosure i'm a 458 fanboy myself, and i put my money where my mouth is and bought a pair.
i think any amp that get's pretty much 'best i have heard' from a wide variety of people is going to attract naysayers from fanboys of other uber-amps. comes with the territory. and if there is any less-than-perfect numbers it will be; 'ah ha!'.
"forget about listening; it can't be that good".....or...."a big THUD".
Technical excellence is a virtue by itself, but it will be the sound that determines the long term success of a new design after the novelty has worn off. The audio marketplace is littered with products that measured spectacularly well but which did not go down as “classics” because they lacked the subjective qualities that kept listeners happy beyond the initial excitement created by a technical innovation.
With this uppermost in mind we set out to create a new generation of amplifiers that measure well enough, but only in a manner that serves the subjective perception of listeners. Oscilloscopes and distortion analyzers are excellent and helpful tools, but they make lousy customers.
Because it sounds better - pure and simple.
Very well put, Mike.
At least darTZeel is out there, with gear being reviewed by magazines. It's not hiding under the "exclusivity" and "you can't buy this" aura that some other manufacturers hide behind...
Yes, the measurements suck. All of them. The integrated, the preamp, the stereo amp, and now the 458. Yet they are the best in each of their respective class, that I have heard.
That goes hand in hand with the fact that one of JA's best measured amplifiers (a Halcro) is an absolute piece of unlistenable sh*t. The same Michael Fremer that thinks the 458 is the best amp ever reviewed the uber expensive Soulution, and he found it severely lacking, while JA found it to be one of the best measuring amps ever.
So what does that tell you? Absolutely nothingOr at least, that you must go out there and listen to stuff, not base yourself on some random specs and preconceived notions of how gear should work.
My 108 stereo amp can't drive low impedances. Yet it kicks the sh*t out of big Krells and MBLs on 89dB Dynaudios and 88dB Sonus fabers. And in another thread, microstrip said this same amp was the best he heard with the monstruous Aidas. If you just read its specs and measurements, you'd never even try such a puny little amp. But he went ahead and did it, and found out it's great.
So, I'm with Mike L here, I just wish I had the means to upgrade to the 458s.
alexandre
If it measures good and sounds good it is good; if it measures bad and sounds good, then you're measuring the wrong thing.
From Sterophile and Hifi News measurements of 458.
Continuous power output with 1% distortion in 8/4/2/1 ohms.
530/900/1025/276 watts.
Distortion at 0,5% - now the power supply begins to struggle in 2 ohms.
500/850/750 watts.
Distortion at 0,2% - big problem in 2 ohm.
450/750/100 watts.
Specs dont say what you will like , what they do is not lie,…
Regards,
Here...
