Don’t know those tubes what’s the whole number ?Al, did you manage to listen to the RD 27as or the AD1?
Exactly as Ked wrote - no more no lessDon’t know those tubes what’s the whole number ?
Did you?Al, did you manage to listen to the RD 27as or the AD1?
Al, still running Roon, so I don’t attenuate digitally. I’ve wondered about the affect of the switch, but hadn’t experimented yet. I appreciate your comments. Was actually hoping someone would go there.Let me say this. I had a unit with no volume on low it for me hurt dynamics on high it was as it should be. If I were you use the volume in the player to adjust for balance
It does not have any negative affects until it’s lowered let’s 20 % but this is player sensitive. May I ask what player you are using ? Also Roon vol control is not a good one where I river or hq player are good ones
Well, ok. First Steve needs to try his RK PX25 to prove that he prefers the KR242. Then he can sell his used RK’s to me, at a discount because they will then be used.Yes, Please get adapters, this is just too interesting not to do and compare the various options you have
And see if you can get the RK 5u4g rectifieres as they really sound quite a bit better than the regular KR 5u4g.
Yes, you should give the 242 a try. If the 242 works in your system, then it is magical
I think my Pacific has that internal gain switch but I haven't found the neccessity to try so far.
Next time I have it open I will have a look...
There are some used RK 5u4g’s available to go with the one I have. But then I’ll have six KR PX25 and two KR 5u4g that are homeless. Then I’ll need a pair of RK 242.
This is good business for KR.![]()
Other than price, higher vacuum, zirconium coating, thicker glass, different shape.What's the difference between RK and KR variants of these tubes?
For me the KR242 is a must have "in my system"
The realism it creates never ceases to amaze me
PS..Don't forget to use Herbie's tube damping rings though View attachment 66051
Allnic has really spun off many pieces of product. The L9000 looks like an intriguing design. I am completely happy with the L5000. It works with 3A/110A in both slots, which decreases the current and increases the output impedance, but increases the gain by about 6db. It also sounds better that way for some reason. Usually, with DHT, when you increase gain, you lose a bit of sound quality. The 3A/107a works well in the first stage, as well as some Western Electric variants, and the dutch postal tube the PT8, so there is some tube rolling options.Other than price, higher vacuum, zirconium coating, thicker glass, different shape.
I see you have an Allnic L5000 DHT. I’m currently auditioning an L9000 OTL/OCL. Pretty amazing piece.
I haven’t heard the L5000 so I can’t compare. But this 9000 is more dynamic and lively than anything else I’ve heard. it also teases out details and separates tones that were previously blended together. I’m rather glued to it. This variant uses the 6080 twin triode but the L10000 uses 300b.Allnic has really spun off many pieces of product. The L9000 looks like an intriguing design. I am completely happy with the L5000. It works with 3A/110A in both slots, which decreases the current and increases the output impedance, but increases the gain by about 6db. It also sounds better that way for some reason. Usually, with DHT, when you increase gain, you lose a bit of sound quality. The 3A/107a works well in the first stage, as well as some Western Electric variants, and the dutch postal tube the PT8, so there is some tube rolling options.
Just can't beat that DHT midrange.
Yes definetely you should try it out but afaik RK242 are unobtainable at the moment...Do you think that with Pacific I should give the RK 242 another try?
I have had a Manley Neo 300b preamp/headphone amp also for some years, that I use as a gain stage for various purposes regularly. However, unlike KS Parks L10000, it is 6sl7 input, is not balanced, and has cap coupling but also includes an optional output transformer coupling.I haven’t heard the L5000 so I can’t compare. But this 9000 is more dynamic and lively than anything else I’ve heard. it also teases out details and separates tones that were previously blended together. I’m rather glued to it. This variant uses the 6080 twin triode but the L10000 uses 300b.
I am very happy with EML 45 MG Ked recommended to me, together with KR 5u4g RK they have tone, timbre and a bit less gain than my former PX25 - which is good.
I’m tempted by the new 242 RK series as some of you suggest they are less dynamic than the regular KR242 and sound warmer.
I tried KR 242 in my Big 7 and it was clearly too much gain in my system -they sounded shouty but in the same time were very transparent and resolved.
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
