I avoided writing earlier, but I believe I was the one who first let PeterA and Al M know that Ian's CAT preamp was highly veiled and colored. I don't think they believed me at first, but apparently they eventually did. The system's sonic signature became quite obvious to me very quickly, and Ian and I took the preamp out within half an hour or less. Basically, it presented the music in a euphonic and veiled way - "fake news" if you will - and all the information came back in a more realistic way when we took it out. However, digital was somewhat thin, and I attribute that to DACs just not being able to drive amps directly. Analog was much better - after gain there was adjusted much higher - but in the end, that also left me wanting more, and for example, I liked Steve Williams' ZYX set-up over Ian's; I am also no longer a fan of unstabilized pivot arms, and I think Ian's is one of them. I believe he'd be better served with a different (and better) arm. But the sheer fact that we had to increase phono gain significantly (12dB?!?) tells me those amps just can't be properly driven directly from sources.
FWIW, I get the same detailed but thin sound from my digital driving my Spectrals - and all Spectrals I've ever had - direct, because simply put, the 1mA DAC output is just not enough.
At the end of the day, I can see why Ian is still looking for a truly transparent preamp that can drive his CAT amps, though I have not heard the DartZeel. Bottom line for me: I just could not stand the coloration and masking of detail of his CAT preamp, and just to give an example, I pointed to specific information missing, like triangle hits, and I believe I had also pointed to solo piano being all over the place. Perhaps the tubes were bad, but I can only judge what I heard. But I can attest to the CAT amps being really good, and I suspect they sound better now.
PS: I HATE Ken's writing style, and I base this on many emails I have seen over the years with others.
