This sound fantastic. I imagine Gryphon has rarely heard their Pendragons sound so amazing. Enjoy.Eva Cassidy "Fields of Gold"
I believe this is the system to which you refer..I believe there was a Pendragon setup in Malaysia or Singapore that had the same alignment as your new configuration.
That individual mentioned he tried both positions and definitely preferred woofers on the inside, panels on the outside.
If you experience some loss of center-fill, try angling the Ribbon Panels slightly toward your seated position.
I believe that he owns Gryphon Kodo in his personal system. He also has some experience with Jadis electronics :Do you mean Dato' Danon Han in Malaysia?
In bass maybe ,but in the important midrange much more energy.Previous setup measured better FWIW…
I understand that ... however the left hand speaker is very close to ceiling .. I would expect some reflections in that case .. my main point was side and rear walls .. my guess is the wonkier upper fr plots in new layout is the result of these ..Line source dispersion is cylindrical, this means virtually no ceiling or floor reflections. There is virtually no dispersion on the vertical axis…it’s why the SPL with distance drop is less with a line source than a point source, which disperses evenly in all axes.
I don't see that.Previous setup measured better FWIW…
Aries Cerat Founder and Head Designer Stavros Danos visited Analogue Fellowship in 2016 with his Kassandra II Limited Edition DAC which maybe the BEST that I will ever hear?! - Analogue Fellowship
Stavros written, “…back from an inspiring trip to Malaysia, where we had some great demos of our Kassandra LE dac… Great people, amazing food and fantastic audio systems made this long trip more than worth while. A big thanks to the guys from Swedish Statement for organizing the event, and...analoguefellowship.com
The lower registers are (IMO) the hardest to get right.
Tom
with broadband tube traps very difficult, they only help with high reverb times. To get rid of valleys and peaks, you need Helmholz resonators that eliminate or boost certain frequencies.
IRS V always didIt reminds me of some Maggie owners who would put the tweeters on the outside. Apogee owners always had the tweeter on the inside…
lol so not true bro sound reflects every where to say it’s not on sides or ceilings is a marketing strategyIt’s a line source…ceiling treatment is unnecessary.
Looks like Pendragon still in the photos at least and...the woofers are on the outside.I believe that he owns Gryphon Kodo in his personal system. He also has some experience with Jadis electronics :
JADIS JP500 SE LINESTAGE...Truly Unforgettable?! - Analogue Fellowship
JADIS ELECTRONICS JP500 SE FOUR CHASSIS LINE STAGE . . An Audio French’s Pride . . It all started with one Frenchman’s quest to make a much more accurate sounding audio tube component which could bring back the emotion felt from the concert. That Frenchman, Andre Calmettes‘ prototypes, tube...analoguefellowship.com
Your correct on dispersion but wrong on room treatmentLine source dispersion is cylindrical, this means virtually no ceiling or floor reflections. There is virtually no dispersion on the vertical axis…it’s why the SPL with distance drop is less with a line source than a point source, which disperses evenly in all axes.
Panels are dipole, which also means figure 8 pattern, which means first reflections are not nearly as much of an issue as there is a null to the sides of the speaker.I understand that ... however the left hand speaker is very close to ceiling .. I would expect some reflections in that case .. my main point was side and rear walls .. my guess is the wonkier upper fr plots in new layout is the result of these ..
I believe that photo shoot took place at a dealers Brad.Looks like Pendragon still in the photos at least and...the woofers are on the outside.
