Often the same. 5 is peak. 3.5 is RMS.You should not forget that most manufacturers specify the output voltage at 5cm/sec 1khz, but Zyx specifies 3.54cm/sec 1khz - the Zyx actually has more like 0.36mV
JR made a comment on the the thread micro is referring to, not sure why he is asking you here https://www.whatsbestforum.com/threads/using-wally-tools.37229/post-912026
Simply because Ron could have some additional information that is not covered in this post - some people come here to learn, debate other people opinions and have a nice time, others love to show their bullying abilities.
Yes, I remember figuring this out at one point as the likely explanation. Thank you for reminding us!You should not forget that most manufacturers specify the output voltage at 5cm/sec 1khz, but Zyx specifies 3.54cm/sec 1khz - the Zyx actually has more like 0.36mV
I think no. a benz lp 0.36mV is the same level here i hear no diffrence. A lyra clavic d.c : 0.25mV (5cm/s, 45° peak).It's significantly quieter, it also says peak not 1khz.Often the same. 5 is peak. 3.5 is RMS.
Can we know what you consider a good quantitative value for resistance to ground and what are the reasons behind your comment?
Nevertheless, if you have a sine wave and it’s peak amplitude if 5 units, the rms (root mean square) value will be 5x.707 = 3.54.I think the subject can become more complicated than that - see this very interesting link
https://www.audioasylum.com/cgi/vt.mpl?f=vinyl&m=1100528
Peak here refers to the amplitude of the test tone, which is generally at 1000 Hz for rating cartridges.I think no. a benz lp 0.36mV is the same level here i hear no diffrence. A lyra clavic d.c : 0.25mV (5cm/s, 45° peak).It's significantly quieter, it also says peak not 1khz.
iF HE IS SMART HE IS GETTING IN SOME BOAT TIME BEFORE THE WEATHER TURNS FOULPeter
Where are you?
it is more than two weeks that you are not active ?!
You would have to ask J.R.
Historically some manufacturers have given their peak voltage spec for 5 cm/sec peak velocity, and others have used rms values.
I am not saying all manufacturers use the same rating scheme. Though a standard helps you compare. I am just noting that 3.54 is the rms value of 5 peak. Peak and rms output follows.
It’s really not an important point and certainly not worth dwelling on. All of these vinyl discussions end up in the ultra trivia domain. The preamp’s volume control will cover a multitude of sins.
Peter
Where are you?
Perhaps such an Amber Alert could be issued from an appropriate jurisdiction other than my system thread?
maybe in his conspiratorial mind you had something to do with the inactivity, hence your thread
I have found another contender!
EAR 534
-- Class A (push-pull)
--EL34s
--bridgeable (I don't know what the resulting impedance is) for about 90 watts
but, it does use negative feedback
I wonder how this would sound compared to JA200?
If you think Jadis doesn't use any you are very wrong. Judge by the sound, not the marketing.
If EAR sparks your interest, I would recommend the 519 (or 509) mono's -- if you can find them, that is. Back in the day, I traded my Jadis 80s for a pair of 519. As I remember it, the EARs had more high frequency extension, clarity, and punch than my Jadis; the Jadis had a sweeter midrange. I used them to drive Apogee CalipersI have found another contender!
EAR 534
--EL34s
So, this is a two-way setup? RD75 mid/high and Analysis Audio bass panel? Or are you also driving a tweeter and some subs? Wavac MD-811 on the RD 75 and Wavac MD-572 on the bass panel?Just for yucks, the Eva Cassidy Spotify cut with 15 watt Wavac on 75 inch ribbons direct drive in an appx. 9 foot equilateral triangle listening field with hand held Galaxy 8 phone, through the maelstrom of YouTube and phone compressions. Bass panel has the bigger Wavac.
