I always heard exactly this as well. But apparently the Joule Electras were prone to insta-blow.Apparently, the Joule Electra ones were also somewhat rich sounding but I never heard them.
which was specifically why i choose the Tenor 75 Watt OTL's over the Atma MA2 Mk2 back in 2001. the Tenor's were linear, but not lean. and i had the MA2's on hand for direct compare at that time.The one I heard that didn’t have that leanish character was the Tenor OTL. Apparently, the Joule Electra ones were also somewhat rich sounding but I never heard them.
unfortunately the Tenor's also did the 'blow up' thing multiple times for me. left a mark. took out Kharma ceramic mid range drivers mostly each time.
the Joule's were a bit too syrupy, missing the speed of the Tenor and not the linearity of other OTL's; but beautiful sounding. and they could really heat up a room.I always heard exactly this as well. But apparently the Joule Electras were prone to insta-blow.
about 10 years ago i did have me some Jadis lust, but it never got physical. i spent some time investigating the brand, but at the time there was not solid distribution in North America and i had a hard time getting info. my speakers would have been a good match for the low to middle output range.Mike, did you ever have Jadis amplifiers in your room?
Wow! This should be a chapter in a new book When bad things happen to good audiophiles.unfortunately the Tenor's also did the 'blow up' thing multiple times for me. left a mark. took out Kharma ceramic mid range drivers mostly each time. might still have them otherwise.
I heard it at a dealer in Switzerland on Dynavox horns…nearly bought them until I read about the issues.The Tenor 75 OTL in Milan back in 2016 was quite an epiphany. Unfortunately the Tenor hybrids not the same level.
better than Jadis. But for power it is the VA 200 which you are not going to find easily
Very interesting! But a little too exotic and unsupported and modified for me.something for the Gryphons?
90w in triode mode should do the trick.....
Sequerra UA-1 Custom EL34 Tube Monoblocks - Uber Rare!
General: Uber rare set of Sequerra monoblocks utilizing a plethora of EL34 tubes (some of the best sounding). Featuring no less than FOUR discrete chassis connected by high quality custom umbilical cords. Original MSRP was $125K in the late 1990's. Yes you read that correctly, and note that MSRP...skyfiaudio.com
And you feel the VA200 has even greater weight in the upper bass to lower midrange than the non-circlotron KR Audio amps?
