That's just not correct .. the figure 8 pattern has a lot of energy at side angles as it reduces to a low level on the baffle plane .. depending on baffle shape and driver ... they are not narrow baffles on the pendragon and I would expect a low db drop at say 45 degrees for some frequenciesGiven the main tower is a dipole, this means a figure 8 radiation pattern. As such there is not a significant issue with first reflection as with a conventional non-dipole speaker. I never put any sidewall treatment for an of my big Stat or Ribbon dipoles, Absorption or diffusion. At the very least it should be much further away from the speaker because the first wall interaction will be much further into the room.
