running balanced cables kills dynamics over a good SE cable in a non balanced system
I think a lot of people would disagree with you on this.
How are they attached to the wall?
I predict a shorter reverberent field in the mid/ high fr region
YesI predict a shorter reverberent field in the mid/ high fr region![]()
Have you tried toeing in the dipoles .. that should reduce side wall reflections a bit more and help with clarity
Phil
I don't know what you mean by a "single-ended system."Running Balanced cables in a SE system , yea i will stand by my statement on that ..!
I've watched with interest this progression--kudos on the results there!I just realized I should try moving the acoustic absorption panels behind the woofer towers to the center of the front wall -- and see if I hear a difference.
Thank you for the kind words!d be inclined to put a centre imaging stack (2) of Mid Range traps with the Diffusors pointing towards the listener.
Leaving your present panels in situ.
Good listening and enjoying your journey.
BruceD
Ron , do you have absorber panels on side walls in front of speakers?Yes
Side wall reflections should be pretty well damped by the side wall absorption panels.
For some reason I seem to like panels pointing straight ahead. Toe-in affected the depth of soundstage, I think. Frequency balance seemed pretty unaffected by toe-in.
I should play more with toe-in but I don't plan on doing it for a while.
yesRon , do you have absorber panels on side walls in front of speakers?
You would think you would get a boost in higher fr listening on axis ..
I have always felt extent of toe in represented a preference in the roll off at the top end
Thanks Ronyes
I think so too. But if the panels are parallel to the front wall then at the centered listening chair I am not listening on axis.
With toe-in the drivers might be pointed directly at you.
Thank you for the suggestion, and for the drawing.Thanks Ron
If you have an idle moment you should just prop those panels at an angle .. making sure it's not a reflection to ear from either speaker .
Not a final solution .. just a test on further limiting panel reflections not in the absorbtion range
The panels are currently absorbing sound at certain ratios over a moderate frequency range then reflecting the remainder so those reflected fr will be causing smear with the direct sound .. this will direct at least any higher fr away from your listening spot ... and hopefully more clarity and more solid sound stage .. if you partially overlay them .. tuck one in say half distance or so behind the other it should be more effective lower down ... anyway that's the theoryThank you for the suggestion, and for the drawing.
What would you be trying to achieve with the angled panels?
