Can't you borrow an SS amp for the (heavy) burn-in of the speakers and use the tube amps only for serious listening?View attachment 104466
I am trying to use the same position and technique and SPL each time. I'm playing the break-in CD basically all day and all evening long except when I go to sleep (only because I just can't relax with super high power tubes on while I'm sleeping). So this measurement is about 50 or 60 hours after the last one I posted.
It is difficult to discern if the break-in is smoothing things out a bit . . .
Work on reducing the rise at 3-6 KHz…probably where the brightness is coming from.
Ron - have you ever paid any attention to the Harmon curve? Just curious.ASC Tube Traps (absorption side facing panels) immediately behind ribbon panels:
Are you getting a reference turntable soon Ron ? The Denon, nice as it is, is not on the same level as the rest of your equipment at this point !
Dear Ron,
Here’s link to the U.S. dealer for the Swedish made Helmholtz resonators with ajustable ports.. Hope it might be of some help.
Home page
Call 847-876-0201, Accurate Construction local builders in Chicago area for remodel contractor, soundproofing a room, and the best home theater system.www.accurateacoustics.com
Yes sir, they certainly do. As you saw on the pics I have used the bass resonators myself, and they do amazing things in troubled rooms. As I had the opposite frequency trouble in the bass region that you have, I used the VR-6 for my bass node at 30-32Hz, and the two VR-4 in each corner for the bass node at 65Hz, which in turn also adjusted the troubled dip at around 100-105 Hz due to the overtune indused by the 65Hz frequency.Yea, this firm builds listening rooms using SMT (Matt's) products.
This system definitely is the most resolving I ever have had.
I think the woofer tower, with its 1,000 watt Class AB Gryphon amplifier, is a brilliant design. It feels like the woofer towers just take control of the room.
She looks Great..... But She need's to be on a Pedestal....-View attachment 104505
Saraswati has been fully resuscitated from a deep suspended animation, and is ready to preside over the listening room and to encourage good, natural sounds!
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
