ROON DSP optimization for Waversa products. Let your ears decide.
ketcham
264
198
275
b5SSSng9C2Qs08YZmb3ezgJyIL7IloThl5kBCXoLLb7ENguKOn6THT7Tsk-_FHjaWlWItLdOLgTT78obhr2jmNP_p6SDsS3mlmWBYxIL7wzGLbnNr3L-Deb--fH5Ju3Yb7JcZMQ
With current circuit design and software implementation, DSD is transmitted either by the industry-standard DSD over PCM (DoP) or between Waversa products using its Native DSD transmission method implemented through Waversa Systems Network Direct Rendering (WNDR). DSD is only processed at the final digital to analog conversion of the Saber ES9038PRO chip.
Waversa Audio Processor only applies PCM algorithms at this time. Waversa is currently beta testing a new proprietary DSD decoder aptly named WAP / DSD. The fundamental concepts of WAP / X that provides Waversa uniqueness in the industry are applied to DSD. All current and future Waversa products featuring current, future or previous generations of this processor will support the unique DSD decoder.
For those individuals who currently own a unit featuring Waversa Audio Processor and use ROON, we recommend setting ROON for automatic WAP processing of DSD files and manual switching to conversion to PCM. This customization will not be necessary once newly released units are on the market and the older generation units are appropriately updated.
Mrn0ZyOPF2CIXuy5iBvq3U-g88TyUqH9gCYmhtXL_MK4E6pmQ9eks-cXqVuaT8B5CVV-q-kOw823fnzvFTLBswarsMyi1Ej201yux4bkKaiA9G0H_1BIMpo4sU0dwJc2Ng4vqkg
In order to do this, first select your Waversa ROON endpoint and find ROON DSP under the speaker icon.
LciAAgHiuxcEs7L3B6hgrHidt5uDAQp9kIGDv8hUys_8WZdh_lsBvg1XR2tStMkJ9OD49sMEQRVkmJk1ZdUmWI2321dE1IOmW17UOjTUWCkZuN5_LecQxk-uxnmrPMFpDWMUImE
Select “Sample Rate Conversion” and click on the “>” arrow. This will open the window seen to the right in the diagram above. Select “Custom” under “Sample Rate Conversion Settings.”
Fjl82SNzfVm2Br2aOtGaQhb1B4yXE3yO7VO3mqx3TUIrlHel2VEdoJHgU-b5CE_lvWBfwW-7nuW4kIkXj8tauXkJxBPaF0wwGYsTtSKxy9DV6JjBkt5pQjy1C4-CkuKI5qMzzFk
Customize the conversion in ROON as highlighted above.
Both the Harmonic (WAP-X) and Dynamic Range Enhancement algorithms may be applied by the end-user using the Waversa devices’ web user interfaces, in addition to the automated proprietary hardware processing methods and signal restoration algorithms inherent to the Waversa Audio Processor.
Once your Waversa units are updated to incorporate Waversa’s DSD decoding method (WAP / DSD), the foregoing ROON settings can be reversed. In Roon, simply disable Sample Rate Conversion or revert DSD sampling rates to “Default”.
Remember to trust your ears and enjoy the settings that make sense for you. Waversa strives to improve adaptability to the unique sound environment of every system.
An Update to this post:
When WAP / X FPGA was released this allows for WAP / DSD and that was enabled by a firmware update. If your firmware is current, then your unit performs WAP / DSD when WAP / X is on. The above information no longer is applicable.
No updates required for the DAC3, DAC3c, VDac - if purchased new April, 2020, or had a physical FPGA update done on or after this date.
If you have any questions if your unit is current, please PM me to determine if the unit is indeed current. Update the Firmware on a regular basis.
Newer generation products are able to even reflash the FPGA chip remotely when the firmware is updated over the internet. This is done now with no or minimal additional steps by the consumer. Some updates when prompted ask for a two-part update with a repowering of the unit in between update stages. The headphone amp, router (April 2020 purchase or physical update), and slimLITE currently exhibit this feature.
More items will also be inclusive to this list moving forward. Please email me with questions. info@kevalinaudio.com.
