Hello, Puma Cat and good evening to you, sir. With all due respect.....how do you figure this?Yeah, it's got virtually nothing to do with the wiring in your home....
Would you be so kind as to explain?
Tom
In my experience, implementing an Altaira ground-plane noise reduction system for a high-end audio system is foundational, along with quality power distribution (e.g. a Shunyata power distributor and power cables). I'd actually go down on the specification of the preamp, if need be, to free up funds for implementing an Altaira system. That's how important I consider it to be.Without reading some of your links.....(yet)
I am planning on a completely separate building, with it's own meter and no lighting associated with said building......with the exception of a powder room for guests that will be turned off when listening.
That said, I am VERY interested in the Altarira and have been for quite some time. Please also understand that I haven't read a audio rag since I was around 10 years old, nor do I plan too.
Without getting into the resistance of the grounding rod(s) and all of that blah, blah, blah.....would this, in your opinion (or others) be more beneficial to the end result as to what hits your ears or would something else be more value oriented?
What say you? Thank you BTW, sir, for your answer above. That is much appreciated.
_________________________________________________________________________________________________________________
BTW, before ANYONE gets defensive about Shunyata (I know there are a lot of fans out there).....There are multiple paths to achieve the same goal. I am looking for the best....or at least the best that I can afford (within reason).
I have what most of you have mentioned. What I am looking for is the imaging aspect and spatial locationality cues that go well beyond the walls within the room. They already do but I am looking to improve this aspect. Audio rags never got me anywhere. Real world feedback, experience and listening have.
Again, what say you.....if you would be so kind as to answer?
Tom
I see where you think your beating the system but your not. Where do you think that new meter ties in. It ties in at the power pole. And your getting all the noise from your neighbors and your own home at that connection. You do have a few feet more wire between you and yourself, but it not the right answer. If your going to say you want your own transforner, I would say why. What is some nebulous utility grade step down transformer doing for you. Not much.I am planning on a completely separate building, with it's own meter and no lighting associated with said building......with the exception of a powder room for guests that will be turned off when listening.
Tom
Have you listened to one in your system, yet?I read Robert's review. If Robert likes the sonic effects of the Altaira system, then I think that's great.
But from his report I don't see what the Altaira is beyond a star ground/common grounding buss system, maybe with some passive components in the box.
Resistance is not the operative factor in this application, it's impedance.I do not think that attention to resistance to ground (in ohms) should be trivialized. I think a low resistance to ground should be a primary objective of a proper electrical infrastructure.
Calling Altaira a passive hub is deceptive and leaves most of us initially unfamiliar down a path of misconception about its functional attributes beyond a star ground hub configuration Imho. From what I understand, it is only passive in the sense of not directly disturbing the path of dynamic current flow from the mains source. But, of course, its function is anything but passive.
No Ron, no AC connection as I’m sure you have come to notice. But the discriminating between passive/active components within the boxes is were I feel a need for some definition. The drains/filters in the boxes go beyond a location for a star ground point in effectiveness. Otherwise, no need for boxes and perhaps no need for Altaira. I believe this is THE one major aspect that discriminates Shunyata Research Altaira from other seemingly similar products. So I apologize for any confusion brought about by what my nonconventional view on what “active” might mean.Are there active electronics in the boxes? Does the box get plugged into an AC wall outlet?
No.Are there active electronics in the boxes? Does the box get plugged into an AC wall outlet?
Bang on the money, Rob. The Altaira system is passive in that it is not powered. There''s no ON switch. Altaira's 7th terminal needs to be connected to the GP-NR terminal of a Shunyata or other power distributor that makes a proper connection to "chassis ground" or use Shunyata's wall receptacle adapter that provides a connection to earth ground of an AC mains wall receptacle, as I mentioned above.No Ron, no AC connection as I’m sure you have come to notice. But the discriminating between passive/active components within the boxes is were I feel a need for some definition. The drains/filters in the boxes go beyond a location for a star ground point in effectiveness. Otherwise, no need for boxes and perhaps no need for Altaira. I believe this is THE one major aspect that discriminates Shunyata Research Altaira from other seemingly similar products. So I apologize for any confusion brought about by what my nonconventional view on what “active” might mean.
Shunyata has been using its noise isolation chamber NIC technology for many years. This uses a ferroelectric material to remove noise on the AC. It’s my understanding that this technology is used in the Altaira boxes as well, except it’s tuned to address the noise found in the ground plane.Are there active electronics in the boxes? Does the box get plugged into an AC wall outlet?
The Shunyata grounding system looks like a copy of the Puritan Audio grounding system. The literature is much the same, Puritan's being a bit more to the point. I had a Shunyata conditioner and cables, I now have Puritan conditioner and cables, they take much less room, are just as good and a fraction of the price.Bang on the money, Rob. The Altaira system is passive in that it is not powered. There''s no ON switch. Altaira's 7th terminal needs to be connected to the GP-NR terminal of a Shunyata or other power distributor that makes a proper connection to "chassis ground" or use Shunyata's wall receptacle adapter that provides a connection to earth ground of an AC mains wall receptacle, as I mentioned above.
Again, folks REALLY need to read all the background and Altaira system information from Shunyata Research before doing an installation/implementation; I can't emphasize this strongly enough.
I posted the links to those above. Those documents were prepared for important reasons, and folks need to read them.
It's true that the NIC technology for Shunyata has been used for years. What's in Everest, Typhon T2 and Altaira is from what I was told, at least the 4th generational upgrade of that technology, how to build the NIC modules, etc...Shunyata has been using its noise isolation chamber NIC technology for many years. This uses a ferroelectric material to remove noise on the AC. It’s my understanding that this technology is used in the Altaira boxes as well, except it’s tuned to address the noise found in the ground plane.
When it comes to noise reduction, passive solutions are often superior to active solutions as they don’t generate noise themselves and they don’t open up another pathway for noise to enter.
