Having a well-executed power install and good ground plane for the main panel and any sub-panels is absolutely the first step. The concept of noise on the chassis ground plane of devices and giving them a path to drain that noise is however supplemental to having a good ground foundation in the electrical system.The Shunyata grounding system looks like a copy of the Puritan Audio grounding system. The literature is much the same, Puritan's being a bit more to the point. I had a Shunyata conditioner and cables, I now have Puritan conditioner and cables, they take much less room, are just as good and a fraction of the price.
We make out own choices, but I found both sets of literature helpful.
I spoke to Mike Lester (Puritan) about the grounding system last week as I was thinking about using it. The problem is that there are three earths, ground, chassis and signal. The chassis and signal earths need to be dealt with separately.
In a nutshell:
- The best chassis ground is a connection to an earth rod, but with UK plugs providing a second route to earth can be fatal, hence the Groundmaster. You put in an earth ground rod and put the Groundmaster between the chassis earth on your conditioner and the cable from your ground rod. The Groundmaster blocks a second route to earth but provides an earth ground.
- If an earth ground connection terrifies you, or you live up an apartment block, the Puritan City is the alternative route to earth ground, sort of.
- The Route Master is a signal star earth, plain and simple.
Shunyata suggest using separate signal ground boxes for analogue and digital components, which seems a bit unnecessary.
http://www.puritanaudiolabs.com/wp-content/uploads/2022/04/RouteMaster-Usage-Notes.pdf
I have new house wiring installed in 2021. Every wire is new, starting from the 3-phase supply in the street. It's connected as three separate 100A supplies, one dedicated to the audio. Everything is in galvanised boxing and the short feed (20 ft) to the audio is under about a foot of concrete and stone, in a well shielded NeoTech drained cable. I don't think I have any grounding issues, but I was going to buy a set of Puritan kit just to see if it makes any difference.
Saying something "is a copy of...." can be taken to have a different meaning than you may intend. I've heard and read exceptionally good things about the Puritan and other solutions out there so Puritan is clearly a great solution, product and company.
It is however not accurate to say the Shunyata grounding solutions "are a copy of" the Puritan solution. Shunyata has had chassis grounding basic solutions for quite a few years back to the TRITON v3 (and possible others) and the first Altaira "alpha" R&D concept prototype existed in mid-2020 and possibly before that. I know this for a fact as I was one of 2 people that the Altaira prototype was sent to for early validation testing and feedback in that timeframe back when it was a single-box grounding noise elimination system long before Shunyata evolved the technology and approach many times to what it is today and ultimately refined it in last 2021 and early 2022 in to purpose-built (CG or SG) 2-box approach.
The Puritan and Shunyata (and others like CAD, Nordost and many others) both have similar target functionality. I would say however that the Shunyata is definitely 'not a copy' of the Puritan device.
As far as having separate Altaira's for CG and for SG filtering, this is the ultimate specialization. The tuning of the SG Altaira hubs are particular to the higher frequency noise that components produce and cross-pollute each other with across the signal plane. The CG Altair hubs are particularly tuned to the different frequencies of noise that occur on the chassis ground plane.
Again, no negative comments at all towards the Puritan or any other similar solution. The Puritan and others seem to be excellent from all I've read and been told; what is best for a given system as usually comes down to a long list of variables including budget, listening results, etc.
