Shunyata Interconnects
Sampajanna
577
652
110
This will come as no surprise to many here. I recently moved my Horizon to a new, higher shelf to make room for my new turntable. This is my first foray into analogue and am loving it so far, but that is another story…. I shoot directly out of the Horizon dac into my mono amps. After moving the Horizon, my shunyata interconnects were too short. I ordered longer ones (Sigma). In the meantime, I got some pur silver Audioquest interconnects a dealer had at the right price/length. I noticed some change in sound making this shift, but was so engaged with dialing in analogue/vinyl I let that stay in the background. Cut forward a week or two and the Sigma interconnects came. A buddy was visiting who is NOT an audiophile at all but will listen. We installed the Shunyata and he exclaimed “That is not a small difference.” The all silver AUdioquest cables were so, so much leaner. They did perhaps have a bit more clarity but were significantly leaner, with less bloom and a much smaller soundstage. The difference was indeed not small at all. The Shunyata are lush, bold and have thicker bass and a much bigger soundstage—truly moving the posts about a perceptual .5 meter… In my system the Shunyata were the clear winners and they aren’t even broken in yet….
Lee
3,061
1,615
1,260
Alpharetta, Georgia
You should hear the Omega line. OMG.
Reactions: Sampajanna
Sampajanna
577
652
110
Would love to. A little outside my spending priorities atm. I am sure they are epic though. I just have some other fish to fry first. Sigma seems to be a relative sweet spot. I use lots of alpha power cables as well for some gear and that also seems to be a price/performance sweet spot
MusicFellow
Active Member
Jan 3, 2022
99
232
38
37
Hi there,
I have a Sigma v2 XLR between DAC and preamp. A really excellent cable - in general and also value for the money. I also had the privilege to try out the Omega XLRs a couple of weeks ago and well … yeahhh.. how shall I put it: They are clearly better (different league even): More presence, more energy, less grainy / harsh (also it‘s a bit bold to call the Sigmas grainy). I will order those once I have the necessary funds and move the Sigma v2 between preamp and monos.
So if you can afford to wait a bit and save the extra funds it‘s highly recommended in my view to swing for the Omegas! :)
PS: I also have both Sigma v2 and Omega power cords and would say that the difference between the two lines is even more profound with the XLRs than the powercords.
Sampajanna
577
652
110
Thanks for the advice! I will try to get some at some point to try
