Sigma NR v2 vs. Alpha NR v2
thyname
127
99
115
N. Virginia
Maybe I am missing something, but looking at the specs, the only difference is the conductor size, everything else appears to be identical, correct? See attached, from website.
So, because of this, if using into a relatively low current gear (I.e DAC, preamp, etc), then there is no advantage to getting Sigma as compared to just getting an Alpha? I realize that for high current Amps Sigma May work better.
Thanks!
zonto
31
4
113
This is my understanding, but would be helpful to get confirmation from the Company. Similar point with the Delta v2 series, just with an even smaller gauge and no carbon fiber head shell.
Is the noise filter the same on each NR cable in the Reference line?
GuillaumeB
267
83
258
UK
www.boyeraudio.com
Reactions: zonto
crion
86
10
238
The thing is, your DAC or preamp may respond greatly to higher DTCD or higher gauge cables. Many have reported this. So if you want to find out for sure in your setup, get a trial of a higher gauge in the range if possible. If your budget allows it.
thyname
127
99
115
N. Virginia
What is DTCD?
As far as the gauge is concerned, if a piece of equipment does not need a high current delivery even at high peak times, why would it benefit from a higher gauge cable?
Thanks!
Dave Raven
1
64
I have both the Sigma & Alpha v2's and they are both excellent and best I have heard from Shunyata IMO. I have owned most all of their cords through the years. I first hooked up a Sigma v2 to my DAC/Pre and it was a big upgrade from the Sigma v1 in my system. I then hooked up another Sigma to my server and did not expect as much of a jump in performance as the first cord delivered but I was wrong another nice improvement! I used the Alpha v2 with my clock and same thing another step up. Both cords are digital glare removers with a sweet midrange, deeper bass and greater detail with excellent transparency vs NR v1. The Sigma has more bloom and depth in my system vs the Alpha same as the V1 difference in my system in this respect. Next I will try the Sigma's on my mono amps to see if they can deliever yet another level of improvement. My bank account hopes not!
crion
86
10
238
Thanks for your feedback Dave regarding Sigma and Alpha v2. That really helps to understand what Sigma NR v2 does more than the Alpha NR v2.
Regarding those mono amps, I think you already know the answer. One thing to add though, the Omega XC can be used on BIG mono amps since it actually is 4 gauge the XC does not have any NR circuit though so keep that in mind. The Omega QR is 6 gauge (same as sigma) but has a QR/BB circuit apart from NR circuit if I remember correctly.
Mcbrion
75
9
313
Connecticut
There are companies that have a 60-day return policy. Use your ears.
Reactions: AnStephen55
