Here is another dish showing the advantage of sous-vide. Traditional duck confit involves 6-10 hours of slow roasting duck legs in duck fat, by which time the tough tendons in the leg become meltingly tender. In a restaurant, duck fat can be obtained by rendering out the fat from the skin. After a while, the legs render their own fat so they can obtain sufficient quantity of fat to confit duck. At home, you will not get enough duck fat unless you buy canned duck fat, and this is very expensive! Sous-vide'ing the duck legs avoids having to buy so much duck fat. Here is the recipe.
Ingredients
- 4 duck marylands (femur removed, and legs frenched)
- 1 cup of kosher salt
- zest of one lemon
- 2 star anise, pounded
- 10 cloves
- 1 tbsp juniper berries
- 1 tbsp black peppercorn
- 4 garlic cloves, finely minced
- thyme leaves
- bay leaves
Method
- Mix all the ingredients together, make sure the duck is well covered, and leave to cure in the fridge for 4 hours.
- After 4 hours, thoroughly wash the duck and pick out any spices stuck to the duck.
- Seal in a sous-vide bag with one bay leaf per bag. Sous-vide at 62C for 48 hours. For an even more tender result (at the risk of the meat falling off the bone when you remove it) - take it to 60 or 72 hours.
- After SV, thoroughly dry the legs on a paper towel then shallow fry to crisp up the skin. Cooked legs can be kept warm in the oven - it will not lose its crispness.
- Serve with your choice of side dishes
As per usual here are some pictures
Here is the duck confit after 48 hours of cooking. Note the juices are still slightly pink. This effect is impossible to achieve with the traditional confit method - medium rare duck legs whilst perfectly cooked.
Frenched duck legs crisping up in a frypan. Note the quantity of oil used. You need to move the legs frequently to stop it from sticking to the pan.
Completed dish, served here with Puy lentils.
Here is another version, this time served with blood orange sauce, blood orange, potato pave, and some veggies.
Ingredients
- zest of one lemon
- 10 cloves
- thyme leaves
- bay leaves
Method
