Bruce B
So butterfly heads are DIN heads versus standard NAB heads not to be confused with nab and iec equalizations ?
Correct
Interesting. Have you done this comparison on recordings known to have been made (recorded) with butterfly heads?I send files to my clients blindly.. labeled as sample 1... sample 2... and so on. I tell them I've used different converters and headstacks. I try to level match the samples to within 0.1dB.
What I hear is a smearing of the soundstage. You really can't pinpoint the direction of instruments. Things like vocals feel bloated instead of fine detailed images.
And the resulting playback differences hold regardless? So it's strictly a playback issue. ?I've done my own recordings (master tape dubs and location recording) with and without DIN heads over the years.
--Bill
ftp://ftp.studer.ch/public/SwissSound/SwissSound16eJul86LR.pdf
Studer themselves discuss the issue in this link.Scroll to the "Stereo to TC article"-page 8.What it boils down to is that Butterfly heads were designed by German Broadcast to enable 2 channel machines to replay mono tapes without the 6db loss of level if replayed on 2 channel machines. This is seen as the only advantage.
Many in Europe refer to heads with 2mm gap as 2 channel heads and those with a 0.75 mm "Butterfly "head as Stereo heads
The 2mm gap in 2 channel allows for a 60db channel separation not possible with Butterfly heads. Machines with Butterfly heads are never used for multi tracking and use mono erase heads as opposed to 2 channel erase heads in 2 track machines.
As Audiophiles it seems logical to me that we should use the 2mm heads for better soundstaging etc. Having said that my best sounding machine is the Mark Levinson ML 5 where ML very definitely specify Butterfly heads.
There's a wealth of good information on my friend Richard Hess' web site, including the signal-to-noise calculations for NAB vs. DIN heads. See especially:
http://richardhess.com/notes/2007/0...2-track-tapes-on-a-din-stereo-butterfly-head/
http://richardhess.com/notes/formats/magnetic-media/magnetic-tapes/analog-audio/025-reel-tape/
http://richardhess.com/notes/category/audio/reels/matching-head-to-tape/
Christopher Campbell
www.cbcampbell.com
