Fransisco, we do not need a reference, but I find it helps, and live acoustic music is the place I want to start. I have also used other systems which I enjoy, which I suppose is more apples to apples. Kedar and perhaps others think I should get out more and listen to more systems, to have a more informed opinion about the possibilities or reproduced sound. I am open to that. I think I am slightly less lost than I once was regarding all of this.
I do find it interesting that KeithR is concluding a year long speaker search journey having heard many different types of speakers and systems. He may end up with a pair of speakers not dissimilar in typology and material to my dreaded Magicos. What does that mean?
Peter, I think you'll find that Ked genuinely believes he knows what's best for everyone, whether or not they know it themselves. Not egotistical in the least Lol.Marc, Kedar is dreaming about his future Master Signature on his future tonearm in his future system. I listen to my Master Signature daily. We both want the same cartridge and natural sound reminding us of the real thing. I am able to listen to something resembling that goal.
Oh, I mean the whole way. Find a sub $1k tt that does "naturalness" to a tee. I've never heard a Rega setup I didn't respect."
My suggestion to Peter would be
the opposite to Ked. Maybe Peter now you've discovered cheaper better options on tweaks, you might investigate cheaper better options on components"
How is this different to what I said?
Here's why the a cable like Ching Cheng that was chosen on a 100% subjective basis is much more of a "tweak" vs a well-made "audiophile" power cable.
Speaking for myself, my idea of a good power cable is one that has been optimized for it's use by using science and engineering. Here are some design considerations.
- Conductors that are rated at about 108% IACS, so are much more conductive than the copper standard.
- Insulation with much less dielectric absorption vs typical PVC, surrounded by filler material with much less dielectric loss vs typical cables. Put simply, the insulation absorbs and releases less energy out of time with the 60 Hz signal.
- Electrical specs ideal for the 60 Hz signal it carries, this means the Inductance, Capacitance and Resistance are much more ideal vs a typical 3-strand power cable.
- Shielding that keeps power supply noise from propagating into the system.
- Grounding that is not run parallel with hot and neutral conductors, not twisted in the same bundle.
- Plugs that use much higher conductivity pure copper electrical contacts vs Brass
As I said previously, I have no issue with people choosing to use whatever makes them happy, but to call CC "neutral" and other, far superior power cables "tweaks" is totally backwards. CC is the definition of tweak, it has relatively poor objective performance and preference is entirely subjective. It's cheap, and that does not make it less of a tweak. It's simply a cheap tweak.
Damn, I forgot that this week. Gotta tell you about this change, Ked...Well am not egotistical because I don't post everyweek saying I have a new epiphany about my system someone listen to me
(...) I do find it interesting that KeithR is concluding a year long speaker search journey having heard many different types of speakers and systems. He may end up with a pair of speakers not dissimilar in typology and material to my dreaded Magicos. What does that mean?
Dave, as a designer of audiophile power cords, I completely understand your position. I have listened to both the Ching Cheng and some fancy alternatives. On a 100% subjective basis, I prefer the former in my system at this time. We have discussed this before and what I am hearing in our private communications. Yes, my preference is indeed subjective and that may not correspond with what is objective.
Well, I can not find any meaning it that ... What is it supposed to mean?
(...) I have listened to both the Ching Cheng and some fancy alternatives. On a 100% subjective basis, I prefer the former in my system at this time. We have discussed this before and what I am hearing in our private communications. Yes, my preference is indeed subjective and that may not correspond with what is objective.
It means his new found sound preference is justified because someone who doesn't listen to the same music as he does concluded his search saying he might buy in future a speaker that is possibly similar to, but is not the same, as Peter's, while Kedar still doesn't have a system
I would like to carry a civilized friendly exchange of posts with Peter in his thread. Could you at less post a smile in your comment?
There has been mentioning of masking of details. I can confirm that the amount of detail from Peter's system is not diminished.
Peter mentioned that I was surprised about how well behaved his room is. I am indeed. Bass is fine without tube traps. Images may be slightly more diffuse than before, but location of musicians is still very clear, so I am not sure if I quite agree with Peter about the magnitude of the sonic changes.
My own room would be unworkable without treatments. Conversely, acoustic treatments in my room have none of the adverse effects that Peter describes for his. Just this morning l was listening to Art Blakey's Jazz Messengers, and the sheer brute energy of Freddie Hubbard's trumpet on Blue Moon and of Wayne Shorter's sax on other tracks made me go "whoa!". If anything, room treatment has made my room come more alive.
Every room and situation is different, and generalizations cannot easily be made.
I do overall agree with Peter and David on pneumatic platforms, power cords and power conditioning.
I don't think so.
The way I see it, you're using power cables that soften and warm the sound, removing the room treatments and having no toe decreases the ratio of direct to reflected sound so you're hearing more reflected sound at higher SPL. I would also say you're adding noise via the AC line.
Further, replacing footers with specific wooden oak blocks and using carefully selected power cables and setup is simply another kind of tweak, it's NOT de-tweaking.
There's absolutely no doubt you can make the sound closer to what you'd typically hear live, I was just a show last night and listened from several different positions and unless you're near front row there is a lot more reflected sound vs at home.
So I get it, and I have no issue with it, I believe people should do whatever they want and achieve whatever sound they enjoy. However, I personally think this is not a de-tweak, it is simply a re-tweak and now it's tweaked MORE than before.
Saying this type of setup is more "natural" and "de-tweaked" is a very excellent use of language by ddk but IMO it's manipulative as who wants a synthetic-sounding tweaky system? Which is what you think you had before... laughable!
I also think we're conflating hearing detail on the recording, close-mic'ed by the engineer, that was intended for you to hear in a way you'd never hear live, and trying to make it sound more like you'd hear it live. Again, nothing wrong with this AT ALL, if you love it, I'm super-happy for you, but let's call a spade a spade.
I described the OBJECTIVE changes and what they are doing, understanding them may be useful to some, especially since they are characterized as de-tweaking, when from my perspective they are simply different tweaks than what you had before.
I also use wood blocks for footers, SAE grade 1 and 13 wool felt and other mundane things for various audio applications. The thought they are "natural" or "de-tweaking" or whatever seems bizarre.
So, I guess you can describe this as more tweaked than before, but the bottom line is that I removed things, I did not add them. And sure, there is some fine tuning going on with my oak footers to balance the sound of my rack support, because in this case I am working with what I have and trying to improve the sound.
