Based on the size of the cap bank I'm thinking a 3 to 4 month run in for the Extreme?
Marc
IIRC Emile commented 1000 hours of break-in are needed for the ExtremeBased on the size of the cap bank I'm thinking a 3 to 4 month run in for the Extreme?
Marc
What's painless about the 1000 hours is that the Extreme sounds great out of the box and continues to get betterIIRC Emile commented 1000 hours of break-in are needed for the Extreme
In my experience this is an anomaly wrapped in an enigma....What's painless about the 1000 hours is that the Extreme sounds great out of the box and continues to get better
Those have been finished however the heatsinks aren’t here yet.
I recommend the high current and ideally give the Extreme its own circuit, its power supply is like 400VAQuestion about power cords for the Extreme.
Several companies (Audioquest, Audience, etc) make 2 types of power cords: high powered (mainly for amps) and source (for source components). The high powered are designed for variable current loads.
Which of these are better suited for the Extreme? Does the Extreme produce a variable current load?
Hi Christiaan, noted with thanks.Hi Robert, congrats on becoming a new Extreme owner! Migrating the core should not normally result in lost playlists or their contents. Did you follow the recommendations on the following Roon page? https://help.roonlabs.com/portal/en/kb/articles/migration#Preparation
Let us know if you need help with that.Hi Christiaan, noted with thanks.
mine arrived today.Finally... my Extreme will be delivered tomorrow... looking forward to it.
Out of laziness, I have not gone back to TAS, but after reading your comment I will give it a shot.@Emile and Taiko team
Since the OS update and with XDMS around the corner, I went back to using Roon after an over 2 year use of TAS. There is no question in my mind that it is the sexy platform of Roon that keeps users glued and always complaining about Roon updates effects on SQ
Well a few days ago I just had to go back to TAS and man was I astonished. IMHO, TAS even after the OS update which created an uptick to Roon continues to perform as good "or better" than Roon
Im sticking with TAS once again until XDMS is released. It sure lacks the interface of Roon but my bet is XDMS will not only equal Roon but will leave Roon in its rear view mirror
April showers, will bring May flowers.......and XDMS![]()
Me either, Ed. but I agree -- time to revisit this now that I've settled in on my choice of Taiko USB drivers.Out of laziness, I have not gone back to TAS, but after reading your comment I will give it a shot.
