PAGE 500 of the amazing Taiko Extreme thread!
Go team Taiko!
Go team Taiko!
Apologies for going off topic, but previously there were thoughts around producing a Taiko Case for the DIY community. Is that project still active and if so, when could one expect them to be available? Thanks.
Well, for the internally-mounted network interface card I'd expect that using the Extreme's own top-shelf and very extreme power supply would be hard to beat.
As far as external devices, good question. Also, wondering if the switch and router will accommodate a range of voltages, say 5VDC to 12VDC assuming a user-supplied external power supply is indeed an option. Or if that comes with too many sonic compromises.
I trust Emile to incorporate into his switch and router design the best sound quality decisions and if that means an included power supply, I'm happy with that.
Steve
Can Emile make one that can interface with our spouses?A “problem solving power supply.” I like the sound of that!
that would be pretty "extreme"Can Emile make one that can interface with our spouses?
I was thinking about exactly this in the shower this morning ;-)
Fundamently very difficult, but even to partly mitigate would be nice as well.
Perhaps we should create a Kickstarter project to remodel an Extreme shower for @EuroDriver ?
Don't those things typically use batteries?that would be pretty "extreme"
Question about power cords for the Extreme.
Several companies (Audioquest, Audience, etc) make 2 types of power cords: high powered (mainly for amps) and source (for source components). The high powered are designed for variable current loads.
Which of these are better suited for the Extreme? Does the Extreme produce a variable current load?
I see Emile beat me to it, but I can confirm that when I experimented with power cords for my Extreme the ones that worked best, that is, sounded best top to bottom were those that were designed for high-current loads. I ended up with a Sablon Prince which very narrowly beat out a Shunyata Sigma NR v2. Both sounded excellent and noticeably better than smaller-gauge conductor power cords. Either one would be a good choice and I am sure there are many others out there.Question about power cords for the Extreme.
The list is endless....I use all Masterbuilt Ultra in my system so for the Extreme I use the MB Ultra Power cord as well as the MB Ultra USB cableI am sure there are many others out there.
Indeed. I’m using a Sablon Prince as well. I might have gone for the King but that huge plug would have covered two receptacles on my power distribution unit and I have every receptacle in use.Prince by Sablon Audio. Great power cable at a reasonable price and the maker of Sablon cables is a pleasure to do biz with. Auditions for some cables in his lines are possible. End of commercial!
Hi Robert, congrats on becoming a new Extreme owner! Migrating the core should not normally result in lost playlists or their contents. Did you follow the recommendations on the following Roon page? https://help.roonlabs.com/portal/en/kb/articles/migration#PreparationMy Extreme was delivered last night. The SQ was so lively yet so relax. Love it. However lost a lot of my Roon playlist after migrating Roon core from MacBook Pro to Extreme. Any advice? Thanks
My Extreme was delivered on Thursday. Put an AQ Hurricane Source on it that I wasn’t using. It sounds fine but am looking for recommendations on a high current cord from current owners. What’s everyone using on their Extreme?
