Correct!IIUC, the board on top at page 530 will be placed inside the Extreme, the second and third one in the BPS.
Matt
Matt
What about a DAC or Amps dedicated power supply?
Wow!I’ve dedicated 1 125A phase from it for audio, wiring is AWG O to the systems, there’s just a single blade fuse
The BPS is a DC (battery) to DC power supply. The only time there is an AC to DC conversion is for recharging the battery.I was asking about a DAC or Amp in general (not a Taiko future DAC).
I thought it was mentioned the BPS could be used with a DAC? So, for instance, with my Nagra DAC and it's separate power supply, could the Taiko battery supply actually take the place of the Nagra PSU, or feed the Nagra PSU, or neither?
I basically don't understand the relationship between the Taiko battery supply and other (non-battery) power supplies.
So it could be marketed as a portable welder too.There is a security concern here, hence all connected devices will need to have a TPM (Trusted Platform Module) chip installed with a Taiko key communicating with the BPS to enable a DC output. The BPS can supply over 1000A of instantaneous current, I accidentally liquified a M6 bolt with it once.
A 24 hour supply for the Extreme in an external box, with PCBs, charger, etc, has about a 16*16“ footprint.
I hope it has the same footprint as the current extreme but only a couple of inches high and designed to sit on top of the extreme thus not necessitating another rack space. The extreme gets pretty warm though, so not sure if this is feasible.Will it be the same height as existing Extreme?
I agree. I hope I don’t need another shelf.I hope it has the same footprint as the current extreme but only a couple of inches high and designed to sit on top of the extreme thus not necessitating another rack space. The extreme gets pretty warm though, so not sure if this is feasible.
the battery stuff is very exciting for the medium term (2H2022?)
any update on how the XMDS software is progressing?
No, it‘s controlled over Bluetooth.Will the bps be connected to the network via ethernet?
Marc
Ok.
By what means will the user set parameters?
xdms?
Is this for the Extreme only or also for 2 or even more further devices?It‘ll require a full sized chassis, from about 6*16*16“. We‘re working on the cases now, should have something to show you soon.
