There’s really no need. Plus, sometimes when you remove the screw to the footer you’re left with a loose nut inside the chassis. It’s just not necessarySteve, if you can unscrew your stock feet would the ideal place for the CS be in the original location of the stock feet? Presunably the chassis is a little bit more robust in those 4 areas?
Noted with thanks.There’s really no need. Plus, sometimes when you remove the screw to the footer you’re left with a loose nut inside the chassis. It’s just not necessary
some in USA already got their EtherRegen swich.
very positive first listening impressions are posted already But with much lower quality streamers
where everthing metters.
I wish someone with Extreme in the room will test if this is a good or bad idea for top server.
They say you can connect it via SFP optical direct to the extreme FO slot.
The only dowside is that this is 100 mb limit on the other side.
SFP cage is 1g but the other side of the moat is 100 mb only.
In this case other options might be still better.
please let us know if someone tested it already with Extreme.
I look at the Extreme as a 2 cable super high tech device. Ethernet in and USB out. I have zero issues and have always used the "KISS" technique or keep it simple stupid. it was that easy. I never see a reason to try to out think a developer regarding his product
In the poll above over 82% of users seem to use their Extreme in the same way. What benefit do you expect to derive that otherwise would be absent without the Ether Regen switch
I suppose there could be. I’m certainly not hearing it in my system that I am aware
Sometimes you don't know something is there until it's not there![]()
As far as I’m understanding this thread the Extreme is an extremely thoroughly designed, developed and optimised piece of kit for local and remote streaming, but with the information on footers, USB cables and fibre optics, we see that its still not immune from its environment. The enemies of great digital sound are, amongst other things:
The Extreme has several measures to address/minimise these issues but its still vulnerable to certain aspects of its installation environment.
- Vibration
- Conducted EMI
- Radiated EMI and RFI
- Jitter and resulting phase noise
- Mains distortion, noise and sub optimal earthing
The casework of the Extreme is built to exclude EMI & RFI and is as optimum as it can probably get given the thorough approach.
The fibre optic input is the definitive way to isolate and therefore avoid conducted EMI and the only noise from this source is going to come from the conversion of light to volts
Vibration is still an issue and we see from previous posts that the Extreme benefits from careful siting that includes at least external vibration reduction
The Extreme includes a very robust power supply, so internal power seems to be highly optimised and stable
Which leaves; conducted and radiated EMI and RFI picked up and transmitted by cables and the mains supply and jitter and phase noise.
The EtherRegen is designed to address exactly those issues, isolating the ethernet feed from conducted noise and reclocking the data. Again as i understand, the Extreme is designed to work with asynchronous DACS, so reclocking of the incoming data stream SHOULD have no effect. However other top class installations have without exception (as far as I’m aware) always shown benefits from greater upstream clock accuracy, so its probably just as important for the Extreme. Maybe its designers could comment on internal measures taken to clean-up and retime the incoming data stream.
I’ve spent a lot of time in ridding my system of the above digital nasties and the results are considerable in terms off achieving fully immersive, highly involving, complex, natural sounding and highly addictive music. I could imagine that adding an EtherRegen could be the cherry on top of the cake....especially considering its price.
I look at the Extreme as a 2 cable super high tech device. Ethernet in and USB out. I have zero issues and have always used the "KISS" technique or keep it simple stupid. (...)
Connecting it optically to the EtherRegen would give us a real sound quality improvement?
I do not think that optical sounds better than copper with the EtherRegen.
Matt
That is certainly how it is designed. Whether you go from the A-side to the B-side or vice versa, the sound should be the "same."
I use a Masterbuilt Ultra Power cord. Can’t get better than that IMOSteve.
I hope to do the same. Plug in and forget.
The only difference is I plan to add Third cabele.
The power cable.
This must be a self powering exterme in your system if you use 2 cables Only.
