That could have done it..There is a famous and great French horn solo in the second movement of Tchaik 5 (says the former French horn player).
Emile, can you, please, share details, photos, about the new Extreme DC power distributor? It’s OK if it’s too soon. Thank you.I spent the entire day here with @Christiaan Punter trying to gauge just that.
Although they impact sound quality in different ways we feel the distribution is as follows.
Setting 100% improvement as a baseline (actual improvement subject to your perception), Networkcard and Switch combined 60%, Router 40%, drilling down further, Networkcard 20%, Switch 40%, Router 40%.
This however does not include the new Extreme DC power distributor, which allows you to power both Switch and Router from one single power supply with significant improved performance over using 2 power supplies with the additional option to tailor the sound to your personal preference.
Can I confirm one thing? It was mentioned previously that ports would be forwarded eg. for VNC to copy files. Will there also be port forwarding for XDMS, so I can control my music from my macbook while still being connected to the main (non-audio) router, which I need for accessing the internet?
1 in, 5 out: 1 unfiltered, 2 default filter, 1 alt filter 1, and 1 alt filter 2.
seems only one 12v LPS will be necessary if the Taiko Power Distributor is used
where did this Extreme DC Power distributor come from or is this related to the BPS coming soon. Color me confused
Dinner....I'm still choking on my morning breakfast cereal as I read thisI need 30 minutes for dinner, then will write an extensive explanation.
Dinner....I'm still choking on my morning breakfast cereal as I read this![]()
So my questions....
1. If the user ultimately buys the BPS , will we still need the Taiko DC Power Distributor'
2. Will an access point be part of the purchase package and where will it fit in the schematic
3. What type wire is used to connect the taiko DC power director to the Router and Switch
