Earlier I missed Peter's point about having the untreated room set up by an expert, with the notion that perhaps the arrangement alone can adequately negate any undesirable effect on the sound caused by the room. I'm absolutely certain that this can be done to some people's satisfaction in at least some rooms.
Sorry I had to cut off some of your text thoughout as it was causing me to go over the max chars.
It sure wasn't easy for me. If indeed I have it. This is my 3rd room and by far my most dificult. For example. I'm too embarassed to say how many years I went between having and not having musical bass because I gave up long ago and musical bass became but a distant memory. The point being that given enough resources and/or perseverance quite possibly anything can be improved i.e. either more musical or more tolerant, which in a sense is more musical, right?
I'm certain also that we could still easily measure with instruments the effects the room was having on the sound at the listening position, and that the average person could easily hear those effects. By placing acoustic treatme......
I'm sure you can. I imagine when a playback system's music presentation is in direct competition / conflict with a room's boundaries it could be rather easy to measure. It's a competiton. But guess what? For those who can meaure the differences It's also quite possibly a confession that at this level, one's listening perspective is still in the listening room. IOW, the confession is that the playback system is failing to keep audible such volumes of what is perhaps the lowest of low-level detail i.e the volumes of the concert hall's volumes of ambient info and much has been embedded in the vast majority of my music library. That would considered a rather unresolving playback system and unmusical playback presentation, right? I'm just trying to say maybe it doesn't have to be that way.
Say you've got SOTA-level recording gear and your at the gymnasium to record basketball bounces and reverberating through the empty gym. Back home, you play it back on your system and it sounds more like a ping pong ball than a basketball bouncing and reverberating. What acoustic treatment might convert that ping pong ball back to a basketball?
Hopefully we're in agreement that the music info any of us hears at theie speaker is going to be percentages less than the 100% emedded in the recording. After all, it is an imperfect world. If one agrees with this, the one question nobody seems to ask is, if I'm hearing less than 100% at the speaker, of say a single guitar note, then are the percentage drops equal across all that note's sonic characteristics or is there a hierarchy of sonic characteristics within the single note that become inaudible first? The answer is, the speaker output of a very inferior system would have a music presentation heavily loaded with the music notes making a laser beam for the recording mic and excluding much of the decay as well as the music note traveling throughout the hall. IOW, the lowest of low-level detail i.e. the recording hall's ambient info is the first to become inaudible and the last or easilest thing to remain audible in a severly corrupted system is the note's inital attack that typically make a direct line for the recording mic's. I'm guessing this is precisely why many are convinced they need acoustic treatments.
I'll try to go with your sports car analogy. Most cars are specifically designed to work on roads that are paved to a certain degree of smoothness. Some are made to handle more roughness with certain compromises in aerodynamics and handling. If we play with this analogy we can ask ourselves what kind of a room is like a smooth paved road and which is like a potholed and rutted dirt road? What is the equivalent to the expert room setup?
Sure you can and you may get some benefit. However, since you piggy-backed off of my analogy, remember, the sports car's fuel is still 79 octane. The implication being that it's still sputtering, spitting, and stalling every 3 seconds. No matter how fabulously paved the road or how fabulously the room was treated. Is this not dealing with the effects rather than the cause? Why defend / support that mindset?
First I'll suggest that the expert room setup is like choosing your line while driving. Where on the road can I position this car so that it's going to take the best possible path? We'll assume that this road is repetitive in it's surface features so that you can meaningfully choose a single line and stick with it.
Ok. But as you think this through are you not coming from the perspective that your listening perspective is still in the listening room? I'm gettting the impression that somehow you guys think having musicians in your listening room is some type of badge of honor. It's not and it never will be. Unless we've somehow convinced ourselves this is now a good philosophy / target. If so, why?
I had just re-posted this video of Nina Simone 1965 to defend a position in a similar thread. In all honesty, do you think the listening perspective here is in my listening room or somewhere / anywhere but my listening room? Does the ambient info here seem like my room's been acoustically treated? If somebody asked me this question, my answer would be, hell if I know, I'm only hearing some perspective from anywhere but the listening room and to the best of my knowledge no room can be treated to generate that sound / perspctive. If the music info ain't there, there's no amount of foam in the world that can restore that missing music info. Yet, this seems to be your position. Why?
Next I'll suggest that an anechoic chamber is like a glassy smooth, perfectly flat road. Any roughness you feel in the vehicle and any impediment to forward motion would not b the road surfac....
You kiinda' lost me. At a minimum, because I would never associate a glassy smooth surface with an anechoic chamber. It's an oxymoron kinda' thing. A room filled with foam maybe and without a glassy smooth surface to be found anywhere within.
I'll say a reverb chamber would be equivalent to super rough off road course, where you can't even reach 5 mph without being shaken and jostled around considerably. It doesn't matter much what line you choose - they're all horrible. ....
Why the reverb chamber? Surely you don't think I'm taking that position, do you? I have wall-to-wall carpet / pad and there are a few small furnishing. I do cosider these or something comparable as minium requirements. That's basic 101 stuff isn't it? We're talking acoustic panels and things I presume "The Audio Expert" discusses because he mfg'ers acoustic panels.
I'm just trying to say after having a few reasonable room basics performing due diligence with speaker placement and subwoofer tuning can do wonders for a playback presentation and it's free to all. As does a system's drastically lowered noise floor. So the now audible volumes of music are able to overshadow (rather than compete with) the room's acoustic anomalies.
Obviously speakers aren't intended to be played in anechoic chambers or reverb chambers. I think it's safe to say though that listening in the reverb chamber would be the more difficult and unpleasant experience. We'd probably end up sitting with a speaker right next to each ear - essentially turning them into big headphones to get rid of the obnoxious room sound. The reverb chamb....
I'm uncertain why you're sharing this. Near as I can tell, none these things have much to do with anything I've ever said. I hope.
My depiction is suggesting that the more capable your system is of filling a room with powerful, accurate sound, the more acoustic treatments will matter. I feel confident that it's true. If you are right up close to some small speak....
Perhaps.
How bad does a system have to be to not potentially benefit from room acoustics? I'd say considerably worse than anybody's system who's on this forum. How rough and awful does a car have to run before you can't even tell that you've driven over a pothole?
As I think I said earlier, most anything can be improved even a little given enough resources. But you seem to speak as if you're coming from a perspective of the playback presentation competing head-on with room acoustic anomalies. Whereas I'm coming from the perspecitve of increased percentages of music now overshadow most/all room anomalies. I suspect one of us prefers dealing with the effects rather than the cause.
