Can anyone post a link or publish the Specifications to the DMC-30SL Reference Preamplifier? I can't seem to find them anywhere. Thanks!
Thanks Lloyd. At least that's a little more info than I had before. Do you think Spectral plays well with Burmester?
Is the DMC-30SL their top of the line preamp?
Get a 30SS Series 2 or FM Acoustics and you will never look for another preamp again.
Understood. Thanks Lloyd.
If anyone else has the specs, thank you. Otherwise, I'll call next week.
If I understand correctly, the "SL" upgrade is probably the last upgrade for a given generation.
You know, some people do electronic design exceptionally well, while they have a lot to learn in the marketing department. Such is the case ___: A) Here, and they should stick with what they do best; B) With Spectral; C) All of the above
