DBT DO NOT WORK for audio. Plain and simple. Trying to apply a method to all situations without understanding the test's downsides, limitations and problems is just plain bad science. Just because DBT works for drug testing does not mean it will work for audio!!!
1. Short term memory is notoriously unreliable. Short term memory has a serial processing bottleneck that affects perception. Thus limited "disc" storage space.
2. CNS arousal aka inverse U effect-eg. one wants least arousal and most perception for test. This can't be met.
3. Interindividual hearing differences swamps out statistical tests.
4. DBT is designed for a null effect.
5. No internal controls.
6. Unfamiliarity of equipment, room, sources in most cases.
7. How can you prove adding another piece of gear in the signal path doesn't affect the sound? As John Curl said, every connection affects the sound.
8. Oh, and these individuals are just a little biased? They're hardly unbiased sources. Why don't you find some things from the other side of the argument. MY PhD advisor would label your argument as parochial-only taking the data that supports your point of view and ignoring that data that doesn't support your viewl. Life and science unfortunately is not black and white but shades or gray, something that engineers only find out after they graduate. (at least the good ones).
Need I add more?
"Double-blind do not work for audio. Plain and simple?" Wow! That sounds like a pretty blanket statement without much qualification, and a little misinformed. Several of your arguments are not universally true (you choose to selectively describe only poorly designed DBT which is very misleading), or are completely irrelevant to your central argument.
1. Memory: So how do you explain listeners who can identify a speaker in a DBT, days after they heard it in a previous DBT test? If they can remember the speaker after several days, then you would think they could remember it after 3-4 seconds? Also it is quite easy to deal with short-term echoic memory (3-4 seconds ) effects by quickly switching components. Oh, I forgot: John Curl who designs amplifiers says you can't use a switcher (see counterargument #7).
2. Stress and arousal depends on the complexity of the task and the expertise/training of the listener. If the task is easy for the listener (through good test design or via training) then peak performance can be attained. The fact that I get very sensitive and reliable response data from my listeners suggests that arousal is not a factor in my tests.
3.If the listeners are carefully selected and trained, the individual differences may well be quite a small effect. Also, you can do statistical analysis of individual listener data to see if there are differences in discrimination, preference,etc
4 So what? Most scientific experiments are designed to test a null hypothesis. Do you have a problem with the scientific method? You formulate a null/alternative hypothesis (e.g. there are no differences in preference among speakers/or there are significant preferences among the speakers) you run a listening test, statistically analyze the results, and you make a conclusion based on the evidence. I tend to focus on perceptual effects that are well above the threshold of audibility, and produce a positive result. So tell me how that proves DBT tests do not work?
5. Can you explain what you mean by internal controls?
6. That's an easy one to solve. You use trained listeners or let the naives get used to the room, program and the task. Let them listen as long as it takes: hours, weeks, years. Scientific evidence suggests we quickly adapt to the room acoustics when comparing audio components - up to an extent.
7. You can repeat the test with and without a switcher. If you get the same results, then you could reasonably conclude the switcher had little or no effect. Moreover, the effect of the switcher is a constant factor for the independent variables being tested, as long as it has no biasing influence you can dismiss its influence on the results. You can also measure the electrical properties of the switcher/cable/whatever and determine whether there is an effect. Without scientific evidence, I would not accept what John Curl says as truth, anymore than I would accept what Bill O'Reilly says on Fox News as truth. Curl is not a scientist, and I doubt that he can prove that "every connection can affect the sound".
8. To make a blanket statement that all DBTs in audio do not work based on half-baked truths, and then accuse DBT practitioners of being " biased " , sounds like the pot calling the kettle black. Take your PhD advisor's advice, and read the audio scientific literature where you will find many examples of DBT tests that do in fact work in audio -- plain and simple.
