I could. And I conceded that in my post . But as I went on to say, as the difference gets tiny, and the metric becomes less known, it becomes progressively impossible to do that.But you could use an appropriate switcher that works up to 20 Khz
What would be the specific protocol to determine that?I also said that if you get the same test results with and without the switcher, then you can conclude that it has little effect on the test outcome.
Well it's clear that we're never going to settle this argument and it's just going to evolve into another wreck audio high end argument. It just seems that you don't want to discuss issues. But just to set the record straight:
In regards to (1), what you're referring to basically has nothing to do with short term memory but the ability to transfer memory into long term memory (I think we all develop the ability to different sounds in our environment, whether it be audio, or different cats meowing). And then one needs to search for those variables that probably stay the same so the ear/brain picks can identify and choose between speaker brands. There is a lot of information that gets lost and never translated into long term as well as a lot of subconcious information processing.
In regards to (5), internal controls are a standard scientific procedure used to detect whether the methodology being used, whether biochemistry, audio, works. In other words, one puts a predetermined amount of chemical, distortion into the sample and sees if one gets the expected answer; if not, then there's something wrong. That same internal control can also be used so as to calibrate sensitivity of the methodology. For instance, below which level a certain say distortion might not be detectable; but at the same time, need to show that the methodology employed can show that the aberration can be picked up also.
And in regards to (8) another word my thesis advisor taught me was parochial, in other words just referring to information that supports your hypothesis and ignoring everything else.
Myles, right you are. Well, not on the individual points; you have a few of those quite wrong, but the big one? DBT do not work for audio?
Spot on! Much better to look into the luminous, polished logo of our new acquisition, feel the emptiness as we sit on our wallet, turn the volume up a bit higher than it was before we put the new component in the signal chain (because we have no controls), and declare it good. No chance whatsoever of expectation bias there. We're all too smart for that.
P
Greg
It doesn't have to be an "either or". ...We have come to see things in very polarized fashion: Objectivist are those who believe in DBT and measures .. Subjectivists are those who beleive in their ears and ears only. I am willing to propose that those distinctions are false: Most Audiophiles are in a continuum, they believe in some measurements or testing and some listening .. THe proportions might change but most audiophiles believe and practice both measurements AND listening ... It would only help to listen sometimes ...blind
Frantz
.................... b) someday Harman may make a $100k loudspeaker and we will need the help of opinions from sighted listening tests by reviewers and customers to help us sell the product
We don't control the audiophile population and their likes and dislikes. So for sure, you will find similarities between some of the topics discussed here and elsewhere. What you will find different is the level of respect that we expect members to show for each other and that of industry insiders. Our level of toleration otherwise is extremely low.Well, that'll teach me to responde to the OP without reading the other 7 pages first. The presence of a sub-forum headed up by Sean Olive is a bit deceiving, I'm afraid. It seems that the voodoo count isn't much different here than it is on most audiophile forums.
This is where our forum is extremely different than others. We are a bit like a shopping mall where every tenant owns their own store. We have many subgroups focused on different manufacturers, with each having its own moderator. We provide the space, they provide the material. The process of self selection where people choose to spend their free time to manage a subforum, also means that those people tend to want to speak to like-minded audiophiles and hence, you see them chatting here collectively.And am I the only one here who is not a moderator?
We have people on both sides of the fence here. More importantly, we have people bringing real data to the discussion rather than pure bickering. To that end, we have given Sean his own area where he is the only one who can create new topics. And by his choice (which we appreciate ), he is allowing members to comment. This is a very unique situation that you are not going to find elsewhere. So if you are a fan of Sean, you will find an uncluttered place to read his views. Feel free to stop after his article if that puts you more at peace . We also have an excellent area similarly managed by Tom. We are privileged to have both of them spend their free time to create such high quality material to educate all of us.Think I'll go see if it's any better in Sean's corner. Not likely, though. The religious tend to follow unbelievers around, trying to convince them to hear the expanded vertical sound stage oozing elegantly from the billet aluminum case...
P
PRICELESS!!!!! Hahahahahaha!!!!!
All I'm saying is that performance and desirability are not always correlated. I could name a couple of speakers whose ultimate performance package sucks but they are great speakers because there are a few things that they do extremely well.
I suppose however that when we get to the most extremely designed, executed and priced products, it is but right to raise the standards to match the expectations.
P
Well obviously you need someone to tell you what to buy.
... And am I the only one here who is not a moderator?...
P
Surely there are advantages in being part of a huge conglomerate Sean, however being unfettered by convention in an artisanal setting has its advantages too.
I'm surprised at your choice of words. I'm assuming that at least a part of that observation hails from your experience in your own lab. Lets take two speakers that have passed through your lab, two very similar in driver configuration as well as in form factor. The ES90 and the Studio 2. The latter is 25 times more expensive, are you saying what I think you're saying Sean? Negative correlation might not be the appropriate descriptor. A sample of diminishing returns perhaps but negatively correlated?
Between the range of $200 to $3000 for loudspeakers, on average, you tend to see a positive correlation between price and sound quality. The competition in this price range is much tougher because this is the largest piece of the pie, and there are many players.
I'm almost proud to say that all I can afford is mid-fi audio, as I know I'm getting a decent bang for the buck. I will never have to worry about considering "snob-appeal" components, which actually works out quite well as it doesn't fit my personal character anyway. And although I surely would love to own mono-blocks, be spinning vinyl on an Oracle Delphi MkVI and listen through a pair of Totem Wind's, I really doubt that my level of satisfaction and appreciation for music would increase.
Despite the fact that mid-fi components may not measure as well as their hi-fi cousins, the additional fact is they offer tremendous value and there are some real undervalued products in this category of equipment.
John
