The new Magico M6, M Pro replacement
XV-1
1,842
234
63
Sydney
#41
Nope. I prefer the look of the MPro so I won't be tempted.
Plus 3. Your speakers look a lot better.....and a lot cheaper.
That said, the M series look light years better than the ugly S series - imo
DaveyF
6,135
133
63
La Jolla, Calif USA
#42
Beryllium is a bad thing?
Not a bad thing...but also not IMHO the best available solution for a multi $$ SOTA speaker. Couple of reasons I think this...1) Tendency to ring as volume increases. 2) Limited extension compared to a great ribbon 3) Propensity to beam.
I think the new YG silk dome hybrid is far more advanced of a driver. So, if I'm paying $172K for a speaker, i want a more able high frequency driver like the YG, plain and simple. YMMV.
Jan 31, 2014
416
7
18
Italy
#43
Ribbons tweeters, do not necessarily extend more then Be tweeters, nor have better power handling, and have lots of other issues, definitely not a SOTA solution. YG new silk dome tweeter is just that, a silk dome tweeter, I am not sure what an aluminum frame behind the dome does but add weight, which is not a good thing, BTW. The tweeter on my S5 Mk2 is the best tweeter I have heard by far, superb extension and certainly does not ring and can handle all the power I can throw at it.
Audiocrack
2,003
63
48
#44
How do you guys rate real diamond tweeters to beryllium to silk dome tweeters? I am quite familiar with the former as well as ribbon tweeters and like them both.
Al M.
4,519
356
83
Greater Boston
#45
Apparently you haven't heard the M Pro. The treble is as clean, extended and at the same time, unobtrusive, as it gets. No ringing, no beaming. At high volumes, too. The diamond coating probably helps as well.
Also the beryllium tweeter in my own 'budget' speakers (no diamond coating there, obviously ;)) is remarkably well behaved (the more I upgrade the system around the speakers, the more I notice that, with the latest being new interconnect/amp stands).
Technology advances, and so do implementations of technology that at first were seen as problematic. Digital, anyone?
PeterA
5,553
448
83
North Shore of Boston
#46
Very well stated, Al.
DaveyF
6,135
133
63
La Jolla, Calif USA
#47
Al, I have not heard the MPro, but I have heard the Q7mk 2 and others in the range. In those examples, I felt that the treble was extended, but also prone to glare and a certain hardness ( I did not hear ringing) that would bother me over time. YMMV.
Unfortunately, to my ears, digital still has a certain "signature" that I can always recognize. That signature leaves me a little cold and is frankly not my cup of tea. Compared to good analog or tape, it's to me a distant third...and again YMMV. If I am plonking down $172k for any speaker, I don't want to hear issues at all...none. That may be unrealistic, but then so is that price IMHO!
Al M.
4,519
356
83
Greater Boston
#48
That must have been system context.
BTW, I cannot emphasize enough: while artificial hardness of sound and glare is bad, a system must be capable of reproducing the natural hardness of certain instruments, e.g. brass as played in all but the most smooth sounding venues. While others may not like any hardness they hear from a system, I simply cannot stand an unnaturally smooth, polished sound. It irritates me. It's hifi-ish.
But then, I trust that you meant an unnatural kind of hardness, Davey.
DaveyF
6,135
133
63
La Jolla, Calif USA
#49
Al, that is correct.
I also do not think it was upstream gear that elicited the sound I heard, since I heard the same issue on other occasions and with completely different upstream gear feeding the Magico's.
BTW, I totally agree with you in regards to the fact that some instruments sound hard...particularly those that are of the brass orientation. This is not what I am talking about at all, since I feel it is a major failing if the speaker cannot reproduce this sound!
Al M.
4,519
356
83
Greater Boston
#50
Glad we agree, Davey!
Also, thanks for the extra info regarding system context. While I have had other experiences, I will not dispute yours. I did notice that those Magico speakers are very revealing of weaknesses upstream.
PeterA
5,553
448
83
#51
Does anyone know if the new M6 is at Munich? I had assumed the "05.17" was a reference to a launch at the Munich High End show, but perhaps it was just an announcement about when information about the new speaker was going to be released.
asiufy
3,248
300
83
San Diego, CA
almaaudio.com
#52
I haven't seen it.
KeithR
3,663
591
113
Marina del Rey, CA
#53
Dave, the M3 was the first Magico I'd heard in a long time without the treble sharpness.
Elberoth
1,901
79
48
Poland
#54
No, not even on display.
XV-1
1,842
234
63
Sydney
#55
Very good dual meaning advertising. It got everyone excited. Round 2 will now start when it comes to seeing the M6 in the flesh,
PeterA
5,553
448
83
#57
Keith, are you talking about the Q and S series, or do you include the older M5, Mini, V2 and V3? Could you be a bit more specific? I do agree that the tweeter of the M Pro, and I assume M3, is very different sounding that the Q series and first generation of S series.
KeithR
3,663
591
113
Marina del Rey, CA
#58
Yes, I am talking Q and Sv1 series - although I did hear the S5 on Constellation once which reduced the effect (and Constellation is known to be tame at the extremes). I heard the M3 on Soulution and wasn't bothered by the treble at all. I look forward to hearing the S3v2 at LAAS in two weeks.
But also, Davey comes from SFs on tubes - that's a totally different sound. Its also not just the extension, but the shape of the treble curve.
ack
May 6, 2010
5,538
195
63
Boston, MA
#59
I heard the M3 extensively recently and I thought the tweeter was out-of-this-world good, very powerful, very well integrated with the rest of the speaker, and evident even at a close distance. It probably matched the seamless integration in the M Project
