Downsides are few but include the need to correctly configure your software to ensure the Pro USB receives bit perfect data from the server.
Hello
I am a very happy new owner of a MSB Premier with Renderer Module.
I have 4 questions for
@DMSB
1/
I understand that for firmware updates, bit perfect playing is mandatory to extract the embedded information from the wave file.
But, for ProUSB/ProISL, why bit perfect data is required?
I have a fully acoustically treated room, I had speakers and room extensively measured to setup a tiny equalization for bass (with Roon). So, what Roon sends is not "bit perfect". How the ProUSB/ProISL can "know" that the track has been modified by the server?
2/
I am using media converters, a Sonore for the the one directly connected to the Renderer, to add some isolation from Network . This has an audible impact... I was a little disappointed in fact, that even on MSB, this kind of isolation was needed.
I know that it may be impossible to answer my question, but I am wondering "how better" may be the ProUSB/ProISL in comparison with my "isolated" Renderer, even if I know that the Renderer itself is source of noise. I will try to have a ProUSB/ProISL on loan.
3/
With ProUSB/ProISL, is it the end of server optimization for USB?
With my media converters, I use a Mac mini as the Roon server on Ethernet, and 0 optimization is needed on the server side, only optimization of the last electrical equipment connected to the Renderer and optically isolated (I have used several DAC with included Renderers, last one before MSB was Esoteric N05XD).
If I go back to USB output with ProUSB/ProUSL, keeping my Mac mini as a Network server (sitting in another Room) I may use some Network renderer as Holo RED or even a Raspberry. As I do not want to move my Mac to my Audio Room , I will also have the possibility to have a long fiber from my MAC+ProUSB to the Audio Room.
What are your feelings about all this?
4/
Last question: I saw that Windows and OSX were supported, OSX, natively. Is the USB Chipset you are using confidential? Just to know if it is supported by Linux/Alsa that is, in my opinion, the best OS to use for USB Audio.
Best and kind regards
Thierry
