Low distortion CAN provide a big, realistic, all-encompassing sound, and this includes invisible speakers and excellent to outstanding sound from all recordings. , and this includes invisible speakers and excellent to outstanding sound from all recordings. This is the you-are-there perspective, 30 feet from a stage that is about 60 feet wide and 25 feet deep, in an auditorium that sits about 1200 and has 40 foot ceilings. You can hear an occasional cough to your side, and applause comes from around you. This is a very impressive and overwhelming sound that makes your jaw drop, the hair stand-up on your neck, and leaves one scratching their head. Amazing, realistic, impressive are the adjectives used here.
Robert, thank you for that excellent and, as Vince said, well thought out post. I am certain I have never read a more clearly spelt out description of the substance of this split or tear between these apparent two camps of thinking about audio playback!
I will say immediately I am in the first camp, as undoubtedly is Vince. I can only imagine the vast majority of of musical lovers being enthralled by your account of a system working as decribed in my quote from your post. In fact, that sounds exactly like listening to a live performance of music!
So, now I am perplexed. You decribe a system working at a quality most people are frantically striving for, yet you are unsatisfied by those qualities.
Tonality needs a separate approach, and as much as I hate to admit it, sometimes requires adding back some desirable distortions, if that is what you wish to call it. The adjectives are gorgeous, sumptuous, harmonious, and intoxicating.
So here's the answer. You are perceiving your system to be a musical instrument in its own right, a very sophisticated version of what every guitar hero has as stock in trade, an effects unit. Depending on what the guitarist wishes to achieve in a piece, he will select a pedal for distortion or tube sweetening, etc. Now, I have absolutely no problem or argument with you're doing that, you have done the research, paid your money and are thoroughly enjoying, by all accounts, the end results of your endeavours. You have had a certain goal and have achieved it. You are very happy with your system in the same way Vince is with his.
Yet there must be something more, otherwise you would not asked about those tips for tweaking a system, I would suspect.
do adagios sound beautiful and hold interest as much as the fast pieces
can you play something soft, subtle, slow, and understated for someone listening to a demo of your stereo, and will they ‘get’ the inner beauty and tension conveyed within the technique?
This seems to be the nub of it. Even though you speak of a system being impressive, in what most people would consider a realistic way, you seem to be saying that they will still fail on this test, that of reproducing almost nothing but silence with brief interludes of tone, of notes. Am I correct here?
If I am correct, and for the moment I will assume that I am, then, unfortunately I will still have to say that the demon, distortion, is still part of the mix. You may feel that distortion WAS virtually eradicated in your first scenario, but I would say otherwise, because then your other statements would not have been made ..
Having low distortion helps the harmonies as an interaction, but it is not the total answer.
That I cannot understand. If that is what the musician was producing, and was picked by the microphone and recording mechanism, then it is the playback's job to accurately reproduce that. If it doesn't, then it has distorted the message. The only other alternative is that the microphones and recorder have themselves distorted the musical content to the point where it can't be recovered sufficiently for the ear/brain to accept it. Many here have argued this, stating that the very process of recording and playback itself guarantees that the outcome will be forever intrinsically too greatly flawed. If that is indeed the case, then your solution is one of the ideal paths to follow. Tim's path, as he states, is one of the other paths in this regard, others may be possible.
Here both I and Vince diverge in our viewpoints from seemingly everyone else. As a result of our personal experiences, and not because of what people have stated or demonstrated to us, we have realised it is possible to achieve a greater level of pleasure from listening to recorded sound. Why this is so is open to debate, and that is what this thread is about ...
And yes, I can go from the first scenario to the second scenario, WHEN my system is working correctly, effortlessly. I could put on Led Zeppelin I at maximum volume, and be enveloped by a massive soundstage, feel my body shivering from the energy of it, then immediately follow that, at the correct volume, with John Williams on classical guitar, or a long, beautifully played violin solo, and be completely transfixed by the beauty of intonation, etc. These things are possible ...
Once again, a hearty thanks for a superb post ...
Frank
