Sorry Tim, I don't think the answer is a theoretical "yes"
Audiophiles are really inconsistent when it comes to whether something is a component or not. For example, a passive crossover built into a speaker is not considered a component, but an active crossover outside the speaker is considered a component, even if there is no passive XO in the speaker. So, what makes it a component? It is because it is powered, that makes it a component.
Okay then. Are passive preamps components, because they are not powered? What about a passive preamp which is built into a power amp - are those components?
If your power amp has individual power supplies for each channel (instead of one power supply for both), do you now have two components instead of one, and have you reduced sound quality because you have introduced more components into your system? Or do they only become components when you remove them from the same chassis and turn your dual power supply stereo amp into monoblocks?
As I have pointed out ... if fewer components are better, then why not forget about preamps and power amps ... and just use an integrated amp? (Ignoring the fact that the integrated amp has all these components built into one chassis and using the same power supply).
My question to people who say that active crossovers are separate components is: what is your definition of a "component"?
