If you look into that a bit more closely it reveals just what good value the PhoenixNET represents. (I’m a user with nothing to do with Innuos btw)Yes, I think so.
Now you have to understand that the set Melco S-100 + Pink Faun OCXO + Paul Hynes SR7T (double Rail) + two DC silver cables, is worth more than twice the Innuos.
Curious...What is the cost in $$ to upgrade the Melco with the PF clock?I actually have a 3 PS combination: Sean Jacobs (Innuos USB Reclocking) PH for Melco S-100 and Farad Super 3 for ISP Modem Router, but all three are isolated by the CCI modules of my Shunyata Everest so I don't think that such a combination influences the sound. If today I had to choose between Melco S-100 PF and Innuos Phoenix Next and considered the Price-SQ question, I would think about it carefully, but if I only considered SQ, and just what the Innuos sounded like with a month, then my choice would be Melco.
I demoed an Innuos Statement last year and used its Direct LAN connection into my previous Linn KDSM, I've since upgraded to the new Organik KDSM. As you are probably aware, the PhoenixNET is essentially this part of the Statement.If you look into that a bit more closely it reveals just what good value the PhoenixNET represents. (I’m a user with nothing to do with Innuos btw)
The unit includes 2 Statement-class linear power supplies designed by Sean Jacobs. This brings some really innovative engineering in terms of how the regulators are designed and connected directly to their consumer clients….with no DC cables required. Super clean, stable DC right where its needed. The linear power supply regulator is connected directly to the network switch chip, so as stated, no cable and no switching power regulators….just clean uncontaminated DC.
The other LPS is tied to the oscillator, a 3ppb OCXO, which itself is tied to the network switch chip, so again no clock cables or loss of precision
If you look at the switch itself, you find high quality RJ45 amphenol sockets isolated with large, high quality transformers and directly soldered to the main board and no LEDs Targeted EMI shielding is provided at emission points and the unit sits on anti-resonance footers specially made and tuned for the unit.
Considering all the above, I don‘t really see anywhere in particular where the Melco/PF/DC7 combination is superior. You could argue that the Innuos uses a 100Mbps network switch chip, but given that it was selected for its much lower noise floor vs a gigabit chip its not straightforward to assume that the faster chip is superior when judged on the basis of SQ. So, different architecture sure but the PhoenixNET is designed from the ground up for audio and the power supply is custom built with a lot of genuine refinements in terms of its ‘intimate’ relationship with the switch section. In terms of performance I find the units different but if I had to pick one or the other I‘d find it very difficult, given that both are exceptional performers and their differences are simply different combinations of positive attributes. The happy thing is that when used together those differences are preserved in the final sound and meld together beautifully, really complementing one another.
Of course there is one major difference and that is in my system all power supplies are by SJ, whereas you have the SJ and PH combination. As all switches do is essentially modulate the PS’s DC into a digital stream, the power supplies do contribute a large amount of their own identity. Also when different power supplies are used together, you get different noise spectra which can sometimes intermodulate to form a more complex spectrum of noise and harmonics.
You’re absolutely correct when you say that its absolutely essential to ensure that you have a good match between components, indeed you’re looking for synergy, beyond just compatibility.I demoed an Innuos Statement last year and used its Direct LAN connection into my previous Linn KDSM, I've since upgraded to the new Organik KDSM. As you are probably aware, the PhoenixNET is essentially this part of the Statement.
I had the stock Melco S100 at the time and, frankly, the Statement didn't make the improvement in my system using its LAN output that the stock S100 did.
The gap was even bigger when I used a Farad Super3 on the Melco vs the Statement, so I didn't buy the Statement and went for the PF upgrade instead.
Also, please be aware that not all streamers like the slower 100Mbps connection - my previous Linn KDSM had no problem with the slower speeds from either the Statement or the S100, but the new model wouldn't play music constantly using this connection, I got dropouts. Fortunately the Melco gives you a choice of connection speeds.
The long and short of it is, unless you've heard both in your system, you can't determine which sounds better.
As I understand it, using Direct LAN out from the Statement is basically using the Statement as a switch - maybe an upgraded switch, but still a switch.The one thing I was not quite clear about is your comparison of a server and a network switch, as functionally they are quite different and I’ve only ever encountered them working together rather than in an either/or situation. I’m wholly unfamiliar with Linn products so perhaps Im missing something?
"Again, using the K50 this way, it is acting as both a switch & server and the Linn is the Roon endpoint."
Congratulation and looking forward to your feedback.Well I did it, pulled the trigger on this..Should have it in 10 days. It's a buffalo bs-gs2016 switch modified with it's owns custom power supply. I will keep folks posted on how it all turns out.
HNE Labs, small shop young engineer/designer in Vietnam. I engaged him when I saw the design, he was friendly helpful (English was good enough) and answered all my technical questions. Build quality looks good, all Mundorf caps, nice toroid, and the PS is based on the DC4 form Sean Jacobs, quality clocks used (2) one for Switch other for the fiber converter (built in) which is an option I like since I want to run fiber and try it out. He's on FB, doesn't have an online presence like website etc. He does alot of business in Europe and Asian markets.Congratulation and looking forward to your feedback.
Any information from where you bought it.
Mr. Blackmorec, may I ask: did you consider the Synergistic Research switch before settling on the Phoenix to feed into your Statement? I also have a Statement and am trying to determine my best option to upgrade the quality of the digital stream into the system. Thank you.Well there’s a can-o-beans you just opened!
At least one positive from all this lock-down and pandemic is that my system has taken some further steps forward. The thing is, anything good that you do by way of upgrade anywhere in your network, be it a new cable, vibration control, better power supplies or whatever brings a reward, and the better your system gets, the bigger the reward becomes. No laws of diminishing returns , certainly not at the level I‘ve been working at. The other observation I would make is that in data processing, the role of the network is to move data. In audio, the role of the network should be two-fold, to move data AND to refine the signal.....regenerating finer and finer versions along the way. We know several things based on the improvements I mentioned above. We know that every stage of the network has the ability to improve the signal, proven by the fact that SQ improves, often markedly. It also proves that the improvement at one stage is passed on throughout the network which therefore must be based on ‘better signal in, better signal out’, which means that any improvement you’d hear is made on top of the improved input, which means that each and every stage has the ability to improve the signal and strongly contribute to the resulting sound quality.
Following the above, you’ll realise that a network should ideally be arranged in ever improving steps. That way its all gains with no or minimised limiting steps. So what have I done?
My system is Modem —>3 Band Router—Wi-Fi—> Ethernet Bridge—>AQVox SE—>Statement server. As you also know I had the AQVox connected to a Sean Jacob’s DC3. Adding that power supply brought such a huge uptick in performance that I added DC3s to the rest of the network. With the very generous advice and help of Nenon I then discovered the virtues and benefits of Mundorf Silver/Gold DC cables. I know some may be sceptical that a DC cable matters, but the improvement these JSSG360-format cables brought is way beyond ‘matters’; its really quite fundamental and massively improves the 3 dimensionality and unlimited spacial abilities, where the system can project an ‘any size the recording contains” acoustic venue with all the spacial ambient listening clues in place and 3 dimensional instruments playing music. With many good recordings the music is completely immersive. I was extremely happy with the way the system was sounding....it had SOTA PR&T, and generated incredible listener involvement. So naturally I wondered what even better power supplies throughout the network could achieve. A couple of calls to Sean Jacobs who‘s based in one of the Yorkshire Dales about 100 or so miles away and an upgrade path for all 3 DC3s was defined. A new, somewhat beefier ‘Statement-class’ transformer was fitted, regulation was upgraded to DC4 units, the case was lined with DC4 damping materials, iec sockets upgraded, 3 DC4 footers fitted and the units rewired with Mundorf Silver/Gold cable.
Installed and fired up, by hour 2 it started to make beautiful music with a wonderful energy and vibrancy. The system took about 3 months to reach a completely stable level of performance and I have to say, it was pure magic.....hugely spacial, 3 dimensional, pure, accurate, incredibly transparent with massive PR&T, with a soundstage as big as whatever was on the recording....sometimes small, sometimes huge, sometimes infinite.
So that’s where my system was when I added a well run in PhoenixNET. I always thought I’d like the chance to review a piece of kit, so I was pretty happy to receive this pre-production unit. I used the standard power cord and patch cord to connect from the PhoenixNET to the Statement. Remember what I said before about a network ideally being based on a series of improvements. Well that patch-cord wasn’t.....an improvement. It was exactly the opposite and proved very, very limiting. Into my attic to fetch the only extra ethernet cable I possess, a piece made and supplied by AQVox. It sounded like it sounded when it was last in my system but at least it allowed me to let the PhoenixNET do its thing, which is what I reported.
I now have my own PhoenixNET hooked up with Synergistic Research power and ethernet cables.
Several other network upgrades include the addition of a Melco S100 with Pink Faun Ultra OCXO and a dual rail DC4 with Mundorf silver/gold for all DC wiring to switch and clock. I also got hold of another Finite Elemente Pagoda Master Reference rack and some Cerabase footers for the 3 power supplies and 2 switches. So now the whole lot is again running in. Already sounds amazing but its still about 2 months for all the Mundorf content and cabling to properly condition.
Hi CDC77,Mr. Blackmorec, may I ask: did you consider the Synergistic Research switch before settling on the Phoenix to feed into your Statement? I also have a Statement and am trying to determine my best option to upgrade the quality of the digital stream into the system. Thank you.
May I ask how much you paid for it, including shipping to US? Thank youWell I did it, pulled the trigger on this..Should have it in 10 days. It's a buffalo bs-gs2016 switch modified with it's owns custom power supply. I will keep folks posted on how it all turns out.
Thank you for the answer, and for tips on cabling etc.Hi CDC77,
No I didn‘t consider the Synergistic Research for a couple of reasons…the major one being it wasn’t available at the time I chose my switches. The other reason would have been to do with power supplies and network architecture. I use Sean Jacobs DC4 regulated supplies with Mundorf Silver/Gold DC cabling throughout my entire network chain and I wouldn‘t want to deviate from that as power supply noise can interact to give more complex spectra including harmonics. The third reason is I have a particular architecture that I follow for my network in that every stage of the network sees an improvement in power supply noise spec, clock specification for jitter and phase noise, vibration control and cable screening. It was easy to maintain this architecture with the Melco and Innuos switches and that architecture is extremely important to the final sound in that it generates compounding benefits that improves the quality of the data stream as it travels over the network.
I wouldn't have thought so.Just got a phoenixnet. Have it plugged in for an hour. Sounds totally distorted. Is that normal at beginning of burn in?
