There is blue marking on one end of regular wire and it is supposed to be near the equipment.
Tang
by 'equipment' I assume you mean the 'electronics' intended to be grounded (not the Troy)? sorry......just wanting to be clear.
Tang
Yes, Mike.
thank you Tang. I will change 2 of my cables to the correct orientation.
hi Howie,
assuming you have enough grounding cables for all the front end gear, do them all. plug the Troy power cable into the same duplex outlet of the grounded gear (or preamp if they are all grounded) for optimal effect.
but if you only have one cable, then i'd first try it on the preamp, and then with your source. then the amps.
Thanks Tang , two mis aligned for me as well . Do not recollect this mentioned anyplace else .
You guys can all make a collective release of breathe LOL!
The Troy party really get going.
To Mike: did you ask Miguel about daisy chain your Troy Sig with the Troy Elite?
