Call Shunyata. They are very receptive to questions and will give you the definitive answer. But my guess, the answer is yes.I am thinking to install Equi=tech balance power wall panel. Is Triton or Typhoon compatible with it since the neutral and earth are not on the same voltage level due to balance power?
The TRITON uses a dual pole electromagnetic breaker. It is compatible with balanced power inputs.
Be sure that ALL of your components are compatible with balanced power and follow ALL of the guidelines set out by Equi=Tech.
good to know. i've got an Equi=tech 10kva 10WQ Wall Panel for my system and have had some curiosity about the Triton-Typhoon and whether with an isolation transformer i would still get a performance boost with those products. i'm just accross Puget Sound from you.
Great! I just order two Typhoon for my monoblocks. The monoblocks will be each on dedicated line.
My plan is to install Equi=Tech just for my audio circuit. One dedicated line from Equi=Tech is to connect my current Triton & Typhoon for front end. Each monoblock will be on its own dedicated line together with Typhoon on the same duplex.The Typhon is not in the current path and has no breaker because it doesn't need one. And it is also compatible with a balanced power circuit.
Isn't the Typhon a Power Strip/Distribution Block with lots of added features?The Typhon is not in the current path and has no breaker because it doesn't need one. And it is also compatible with a balanced power circuit.
No. The that is the Triton. The Typhon only adds additional noise reduction.Isn't the Typhon a Power Strip/Distribution Block with lots of added features?
A question for CGabriel: Would you expect the Equi=Tech to supply any additional benefits beyond what the Triton/Typhon combo provides?
How can a product that provides power distribution not be in the current path?The Typhon is not in the current path
Did UL determine that when they tested the unit?........... and has no breaker because it doesn't need one.
There are technical benefits to using isolation transformers. They can provide a level of protection from noise and impulse disturbances coming from the power grid. However, there are very significant caveats when used for high-end audio systems. DTCD (dynamic transient current delivery) is critical to sonic performance for high-end audio components. The instantaneous current capability of a transformer is determined by its energy storage rating which is directly related to the size of the transformer. For good performance in an audio system the isolation transformer needs to be significantly over-rated beyond what the continuous current requirements are for the system. The bottom line is that the transformer needs to be quite large. If the transformer is too small it will significantly reduce DTCD and cause a noticeable loss of sonic dynamics. Most consumer systems do not need the level of protection provided by isolation transformers. A simple and inexpensive "whole house" surge protection system installed at the electrical panel is quite sufficient.
There are sub-classes of isolation transformers, the balanced power isolation transformers being one. Unlike the normal power supplied to a home outlet, balanced power supplies AC voltage to both the hot and the neutral conductors. This has the potential to cause problems with some equipment and care must be taken in the deployment of such a system. It is too complex for me to explain here. This is why it is somewhat controversial in anything other than commercial installations. The technical benefits over a connventional electrostatic isolation transformer is debatable.
Our factory is located in an industrial park where there are neighboring businesses that use heavy electrical equipment that can cause very significant power line disturbances. For this reason we use an isolation tranformer for the dedicated power circuits that feed our reference audio studio. The tranformer is actually physically larger than the transformer that feeds AC power to our business. It is heavy, large, expensive and it hums. Not something I would want in an audio room.
We have a dedicated electrical distribution panel for the audio room and it is fitted with a whole house surge protection panel.
The Triton and the Typhon provide power distribution and sonic performance enhancement to our reference audio components.
So in your view, you think that Equi=Tech wall panel will not help DTCD and actually it will harm it? The panel I am going to install is 10kVA. It should have more than enough reserve for my audio system.
Using an Equi=tech wall cabinet, I don't see how electrical delivery can get any better, but I've been wrong before!
It would be interesting to try the Triton/Typhoon in my system to see what it does.
maybe when I try it I can drop it off at your place and you can try it, or vice versa.
Cool..... would look forward to it!
