Triton and Equi=Tech wall panel
So in your view, you think that Equi=Tech wall panel will not help DTCD and actually it will harm it? The panel I am going to install is 10kVA. It should have more than enough reserve for my audio system.
I think you might read what I actually said again.
Ok got it. As long as the transformer is significantly more than required, it should be fine.
Yes, high quality tranformers can be helpful and beneficial if they are sized correctly.
Center tapped transformers (balanced power) have more installation requirements regarding what can or should be plugged in to the balanced circuits.
There are many professional installations that use balanced power. All of them where professionally planned and implemented. Check with the transformer supplier and ask questions.
Our products are currently being used in many pro studios some of which use balanced power. Check our website for a list.
