In theory I could measure it in my lab with photomultiplier tube and oscilloscope. Just need some time to try it out with the LeCroy Waverunner scope. We have the system setup to measure laser pulses, light scattering and mass spectra (coming from a micro channel plate detector).Yes, it would help to know what numbers the SpeedNic is using. I would doubt the duty cycle is as short as you proposed, but it is technically feasible and possible. On the RR tach, there is a built in software triggered stobe that I used during development to check for trigger ambiguity, and never removed in production. The pulse width of my strobe was 300uS and required a very bright white LED run at higher current than normal to be visible. Even at 300uS, the flash does not appear very bright. The brightness of the LED is directly proportional to the current. For a single ended pulse (PWM) the RMS value of current will be sqrt(duty cycle), so in your example the brightness would be sqrt(1/10,000) or 1% or normal.
My purpose for crunching the numbers in the previous post was to illuminate the fact that strobe disks can have limited resolution, especially when using an ambient light source, and the difference between the Timeline and a normal strobe disk, even if using a crystal controlled source.
I was basing my pulse width on some literature and experience with laser pump strobes. Could be I am off by a fair bit. But, is it the full pulse we see or the leading edge? Then rise time would matter from zero to full output and not how long it is sustained.
