How do you know what a cable sounds like until you insert it into your system?Why -- because I know what I want?
If you like the cable, what's wrong with a little adjustability?
I'm not sure what I think of your philosophy on grounding. Grounding is not a filter. I honestly am not totally sure what ground boxes do. If they are connected together, they can be a parallel path to the earth ground in the power cable. So why don't they cause ground loops? If the piezo crystal is truly short electrons in its atomic structure and there is a way to encourage stray electrons riding on the case and in the signal of a component to the box, what is wrong with draining them off. That is just a fundamentally lower noise environment for equipment to be operating in. Always good in my book. But then again, I don't really know what a ground box does.Tom,
the term 'grounding' has so many meanings to audiophiles in system building that it's important to differentiate between proper basic A/C power grid grounding and other let's say basic grounding (although these things are also related and peripherally involved with more extreme grounding). and i view these housekeeping areas of grounding as fair game for us to be through about to judge our system 'naked'. for the gear and our acoustic set-up to be judged on a basic level. so we are choosing the right gear for our direction in an honest fashion.
for instance i view my Equi=tech 10WQ Wall Panel system with it's separate ground rod as part of basic grounding. and i view all my power cords and Furutech NCF plugs and outlets as basic grounding. i view grounding chassis here and there, or grounding your racks, or using Star grounding as basic grounding. we can go down that road a long way and still stay with my view of basic grounding. in many ways most of this type grounding is almost free.
'extreme' grounding is adding boxes with exotic materials, or maybe powered boxes that are doing this or that, or say a grounded interconnect attached to a separate grounding box. in my system i have -2- Tripoint boxes, the Elite and the Troy. i have -6- Entreq ground boxes, i have -5- Taiko Setchi ground boxes, and a single Pranawire Gounding Interceptor. these boxes are connected to chassis or signal path and add something, or take away something. at one point i had two sets of Tara Labs Grandmaster Evolution interconnects with dual mono block grounding stations. even though it's an interconnect the added grounding boxes makes it 'extreme'.
maybe others might view the line dividing 'informed basic grounding' and 'extreme' grounding differently than me. maybe they @marty cut hairs that my choice of 'Rhodium' NCF plugs instead of 'Gold' NCF plugs is 'extreme'.....and something not neutral. ok, everyone is entitled to their opinion. but ultimately to judge a starting point to feel your system is doing things right and hitting your reference i think it's important to stay basic with grounding.
obviously there are plenty of tweaks not related to grounding that also should be removed prior to significant system building decisions too; but 'extreme' grounding is one where it can fool you into not seeing the forest for the trees. 'extreme' grounding should only be additive, and you should always listen to new gear with and without it so you know what is actually going on.
maybe your choice of gear is significantly changed with or without grounding. and you make a decision that 'A' with extreme grounding is better than 'B' with 'extreme' grounding....but 'B' is better without that 'extreme' grounding. and maybe you prefer 'B' naked to 'A' with extreme grounding. at least you have uncovered a deeper truth and can make a more informed decision since you have more information. but unless you have your process of considering the 'extreme' grounding effect how could you know that?
btw; generally i do not view resonance treatments as 'tweaks'; but some are quite extreme. and can have tonal influences that are significant. so resonance treatments need to be seriously vetted to make sure they are completely friendly and not just applied without investigation. and when changing gear resonance treatments need to be again visited. this might sound obvious but it is important to realize cause and effect.
If you were talking about filters, I would understand better your position. With a filter, people have to be very aware what the filter is doing as you change any component. There are plenty of times I have altered someone's power supply and a filter that was being used is no longer beneficial.
whether the examples i gave are 'filters' or 'tweaks' depends on semantics. i did not call them either thing. they enhance the musical realism by way of being attached to gear. since these products are attached but not to a normal plug, i group it together in a grounding category and the manufacturers generally refer to these products that way.I'm not sure what I think of your philosophy on grounding. Grounding is not a filter. I honestly am not totally sure what ground boxes do. If they are connected together, they can be a parallel path to the earth ground in the power cable. So why don't they cause ground loops? If the piezo crystal is truly short electrons in its atomic structure and there is a way to encourage stray electrons riding on the case and in the signal of a component to the box, what is wrong with draining them off. That is just a fundamentally lower noise environment for equipment to be operating in. Always good in my book. But then again, I don't really know what a ground box does.
when you do this kind of experiment, does it take time for the effect of grounding to become apparent? In other words, is there settling in time for grounding (powered or otherwise)?maybe your choice of gear is significantly changed with or without grounding. and you make a decision that 'A' with extreme grounding is better than 'B' with 'extreme' grounding....but 'B' is better without that 'extreme' grounding. and maybe you prefer 'B' naked to 'A' with extreme grounding. at least you have uncovered a deeper truth and can make a more informed decision since you have more information. but unless you have your process of considering the 'extreme' grounding effect how could you know that?
the last time i disconnected the grounding was Nov 23' when i added the Pranawire Ground box to my Wadax Server. i removed the Elite grounding connection from the power supply of the Wadax dac and did an A/B with and without the Elite connected. i had previously just tried it quickly on the Wadax server to see if it was worth further investigations. it was. it was clearly better with both.when you do this kind of experiment, does it take time for the effect of grounding to become apparent? In other words, is there settling in time for grounding (powered or otherwise)?
This is the very first connection one should do when installing a Grounding device, The incoming Earth / Ground , just before the consumer unit , A very specific grounding device is used for this. Your entire ancillaries being audio or video will benefit greatly from this. Then you add Grounding devices to your ancillaries, deciding which is best, chassis or signal grounding.Tom,
Are you connecting to chassis or signal. Which has a bigger affect. How much of your grounding goes to a stand alone device or something with a drain to earth ground. Does one or the other have a larger affect?the last time i disconnected the grounding was Nov 23' when i added the Pranawire Ground box to my Wadax Server. i removed the Elite grounding connection from the power supply of the Wadax dac and did an A/B with and without the Elite connected. i had previously just tried it quickly on the Wadax server to see if it was worth further investigations. it was. it was clearly better with both.
previous to that, it was when i did my Wadax<->MSB/Taiko Extreme compare in Jan 22'. in that case i disconnected the Tripoint Elite from the MSB and the darTZeel preamp and did that compare without them. i did leave all the grounding on the amps and bass towers. i wanted to be able to do a fairly speedy A/B and not have that as an issue. those particular grounding cables are the Thor Master Reference ground cables which are quite easy to hear much of what they do in a quick A/B. those cables are very stiff and from time to time work their way loose and when that happens i do notice it quickly.
it's my habit to go around and inspect the grounding cable connections every few weeks. but mostly they do stay connected. the Entreq connectors get loose over time so i make sure they are tight.
last year when i got the Massif Audio racks, my sources were completely disassembled for a few days and then put back together. the system was really horrid for the first half day then started to come back alive. i'm sure moving the Elite box (100 pounds +) was a big part of it.
so to answer your question; yes things do take time to become optimal. but it's not the same for every piece or place. but always the next day it's 'better'. why it's better is open to interpretation. i agree 'settling' is much of it.
Every saleman wants you go do as such!!!!!!!!!!!!Maybe this is too simple for OCD audiophiles, and I'm not at all sure that I agree with it, but what do y'all think of this:
-- Cease trying to figure out how these things work. (This is very difficult for me personally because my amateur radio background gives me an (admittedly stale but not completely inconsequential) understanding of basic electronics, grounding theory, antenna theory, RF principles and EMI/RFI. So it's very difficult for me not to want to understand the theory behind these devices, and the actual method of operation of these devices (i.e., how do they actually work?))
-- Cease looking for specifications and objective measurements.
-- Cease looking for independent proof of efficacy.
-- Ignore all marketing copy, claims and advertising.
Instead:
1) Try it in your own system.
2) If you hear a difference, do you like the difference?
3) If you like the difference, is the difference worth the purchase price?
4) If the difference is worth the purchase price, then buy it. If the difference is not worth the purchase price then return it.
PS: Don't be embarrassed, or afraid to report, that you do not hear a difference!
i do not currently have any signal grounding. all chassis connections in one way or another. some to a grounding post, some to a chassis screw by various means. in some cases it requires specialized pieces to do it right. Tara Labs has small little 'taps' which i've used to good purpose. i learned about these little doohickies when i owned the Tara Labs Grandmaster interconnects. and used them since. the best screw hole connector i have found. you do need the plug that fits into them which is then connected to a ground wire with a spade on the other end.Are you connecting to chassis or signal. Which has a bigger affect. How much of your grounding goes to a stand alone device or something with a drain to earth ground. Does one or the other have a larger affect?
could you post a link to exactly what this picture shows? or give it a name or description. thanks.This is the very first connection one should do when installing a Grounding device, The incoming Earth / Ground , just before the consumer unit , A very specific grounding device is used for this. Your entire ancillaries being audio or video will benefit greatly from this. Then you add Grounding devices to your ancillaries, deciding which is best, chassis or signal grounding.
What do you hear when you say bad efdect from grounding.i do not currently have any signal grounding. all chassis connections in one way or another. some to a grounding post, some to a chassis screw by various means. in some cases it requires specialized pieces to do it right. Tara Labs has small little 'taps' which i've used to good purpose. i learned about these little doohickies when i owned the Tara Labs Grandmaster interconnects. and used them since. the best screw hole connector i have found. you do need the plug that fits into them which is then connected to a ground wire with a spade on the other end.
for a few years i did signal grounding connecting my Entreq Poseidon box (each section is isolated) to the negative speaker terminals of the dart mono blocks. but i found it a net negative so ended that and re-tasked the Poseidon to the bass towers to a very positive effect where they are connected to chassis screws on the active bass amps.
the Entreq, Pranawire and Taiko Setchi devices are stand alone....not attached to any 'earth' or A/C ground. the Tripoint Elite and Troy Signature are plugged into an outlet with a dummy plug only connected to the A/C ground. each Setchi has a 9v battery which i change every couple years.
not sure what you are referring to. maybe the signal grounding to the negative speaker terminals from the Entreq Poseidon net negative i mentioned?What do you hear when you say bad effect from grounding.
Maybe this is too simple for OCD audiophiles, and I'm not at all sure that I agree with it myself, but what do y'all think of this:
Instead:
PS: Don't be embarrassed, or afraid to report, that you do not hear a difference! This is a hobby, not your career.
This is a connection to the main incoming Earth / Ground just before entering the consumer unit, on the other end is a specific grounding device. You will start to hear more opening up of the soundscape after some hours, the full performance is after a few days and more.could you post a link to exactly what this picture shows? or give it a name or description. thanks.
You hear a squeezing/ colouration , in particular in the mid range , lifeless and loose the soundscape / musical flow.What do you hear when you say bad efdect from grounding.
sorry, but i'm still not exactly clear what you are referring to.This is a connection to the main incoming Earth / Ground just before entering the consumer unit, on the other end is a specific grounding device. You will start to hear more opening up of the soundscape after some hours, the full performance is after a few days and more.
Connecting to the negative binding post on the loudspeaker side is the correct way to go and offers a very good uplift in performance. It is only recently after new development I recommend this way. Your loudspeaker cables do act as antenna/ aerials in picking up noise, this is why you connect at the loudspeaker end.i do not currently have any signal grounding. all chassis connections in one way or another. some to a grounding post, some to a chassis screw by various means. in some cases it requires specialized pieces to do it right. Tara Labs has small little 'taps' which i've used to good purpose. i learned about these little doohickies when i owned the Tara Labs Grandmaster interconnects. and used them since. the best screw hole connector i have found. you do need the plug that fits into them which is then connected to a ground wire with a spade on the other end.
