Steve williams
Site Founder, Site Co-Owner, Administrator
It would be my pleasure as long as I get an invite to hear your new DAC
The Apex depends so so much on the upsampling scheme, filter and map settings I learned. If any one are out of whack it becomes clinical. This gets somewhat further compounded by the UX on the dCS. You are only able to set filter settings for a format when that format is present.Excellent post! And what a comparison1 Wow!
I too favor the Horizon, but have not heard many of these dacs. I heard the MSB Reference and it was great, I haven’t yet heard Wadax. I have heard the Kassandra and also loved it. My only divergence from your findings, and this is just my experience, is the Apex. I have heard it in 3 systems now—2 well set up. In fact, I found it fatiguing in 2 of those rooms. It was less clinical than non-Apex stack, but still soullless iIMO. It failed to pull me in, to make me surrender and forget myself… It was not my cup of tea at all. Also, I would add the Playback Designs MPD8 to this list. It is an excellent dac.
What was the dunce DAC? And why? By omitting it you cast a shadow over all the ones not on your list. Also, including it will inform readers of your preferences as much as the ones you did list.Summary: I only auditioned one DAC that I just did not like. Out of respect I have omitted it.
Hmm not sure I'm with your take on this one. I don't see how not listing a DAC he didn't like cast a shadow on anything.What was the dunce DAC? And why? By omitting it you cast a shadow over all the ones not on your list. Also, including it will inform readers of your preferences as much as the ones you did list.
Thank you so much for that in-depth review. I greatly enjoyed reading it. Congratulations on your MSB Select II DAC. I hope it brings you many years of enjoyment. If you decide to step up to MSB’s Digital Director, please post a review with your thoughts. MSB says it provides a significant improvement in sound quality.As many of you know, I set out to audition a number of the leading DACs in my system with the goal of identifying the ideal fit for my ears. Below is a bit of a stream of consciousness summary of how it all sounded and went for me.
But, first please let me outline a few parameters and disclosures...
- These notes are my thoughts and impressions based on my impressions. They are not in any way meant as a declaration or even a proper review.
- Not all of the DACs were inserted in the system identically! Some of them were heard with a streamer or a clock or bespoke cables. I will try to identify the setups below. For those looking to 'sweep the knee' on this post - one DAC had a FTA USB while another had a $5 USB!
- Many DACs were connected to the pre-amp using Transparent Opus Gen 6 balanced interconnects that were not tuned for the DAC. The tuning of the interconnects makes a noticeable difference - more so depending on the variance from what it is tuned to vs. the actual component. I have noted where this was the case.
- I tried to remain consistent with music tracks for all DACs with music ranging from classical to rock to EDM to folk
- There was an attempt to equalize the sound pressure across all
- Each DAC was compared against a dCS Vivaldi Apex stack (Clock, Upsampler, DAC)
- DACs were setup with the Boulder 3010 using trim functions for equalizing so that we could instantly switch back and forth and A|B|A listen
- Some DACs I had for days and others for only a few hours!
- I am not bought into, "...how the artists intended it..." I do not care too much about measurements. I have firsthand seen debates between artists and engineers occur on mixes to the effect of, "...it sounds best under x! But, we should mix it this way as most people will listen with y..." Let me say this another way. I care about music that moves me emotionally. I have regularly smiled when I read statements about "...how the artists intended..." I suggest that these people speak to some artists on how the process works.
The system that was used is outlined below.
- Source: Roon Nucleus connected via either network or by USB (specified per DAC)
- DAC: Variable
- Pre-Amp: Boulder 3010
- Amp: Boulder 3060
- Speakers: Wilson Alexx V
- Cables: All cabling is Transparent Opus Gen 6 (power cords are all Gen 5)
Basis system: dCS Vivaldi
- Connections:
- Ethernet connection to network
- Transparent Magnum Opus Gen 6 balanced interconnect *tuned
- Audition setup: Dealer loaned it to me
- Impressions
- Detail and resolution as good as I have ever heard
- Can be a bit harsh upper range vocals
- Wanted for more body - it can be somewhat thin
- Incredible ability to resolve complex transients
- Wanted for longer more natural decay - felt like it was 'just the facts' and absolutely no more
- Lacked some warmth
- Upper mid-range balanced
- GREAT on classical music, processed music and EDM
- Other: The dCS is highly dependent on the Upsampler and DAC variables that are user set. There is a filter on the Upsampler, an Upsampler output formal (DSD etc), a DAC filter and a DAC map. And, they all affect the sound.
Lampizator Horizon
- Connections:
- FTA USB from Roon Nuc
- Transparent Opus Gen 6 balanced interconnect *not tuned
- Audition setup: Sent for audition
- Impressions
- Wow! The holographic soundstage is amazing!
- Density!
- Decay
- Air and space - instruments are there!
- Not a quick and resolving as the dCS but so so musical
- Other: The Horizon changed sound signature in the days I had with it more-so than solid-state gear I am used to. I was urged by Steve W to be patient but I was not. I have since wondered as the person I sent mine to indicated that once broken in it was incredible. I do not doubt it. That first night I plugged it in it was like nothing I have heard before.
Nagra HD X
- Connections:
- Source was replaced by an Ideon Absolute Stream and Clock
- USB to DAC (dealer brought top end Audio Quest)
- Audio Quest Dragon balanced interconnect to pre-amp
- Audition setup: Dealer onsite audition for 2 hours
- Impressions
- Smoother than dCS
- Nice linearity and body with classical and rock
- Struggled v dCS on some quick transients
- Less musical than dCS on highly processed music and EDM
- Mid-range focused v dCS
- Other: I could have happily gone with this DAC
Infigo Method 4
- Connections:
- Bespoke streamer brought by Infigo Audio
- USB to DAC
- Transparent Opus Gen 6 balanced interconnect to pre-amp *not tuned
- Audition setup: Infigo Principle brought to my home for a couple hours
- Impressions
- Warm - almost tube warm
- Soundstage was similar to dCS
- On some dance tracks such as Senorita (Shawn Mendes and Camilla Cabello) it was get up and dance engaging.
- Seemed to really shine with upper midrange centric tracks
- Other: The Principal of Infigo is one of the nicer and most intellectually curious people I have met in audio
Wadax Reference
- Connections:
- Wadax Reference Server
- Specific optical cable between server and DAC
- Audio Quest Niagra 7000 power conditioner
- Ethernet to server via Audio Quest Diamond
- Audition setup: Dealer visit for 2 hours
- Impressions
- Linear
- Smooth
- Noise floor higher than dCS
- Very musical
- Server adjustments - Gain etc made massive changes in sound and were necessary
- Soundstage very similar to dCS
- No matter what music thrown at it it sounded great
- Very balanced
- Handled transients as well as dCS
- Other:
- I do not understand the Wadax haters. It is a damn impressive DAC. One might argue value but, at least in my system to my ears, it was a wow.
- I suspect that the server is required for the sound on this one.
Aries Cerat Kassandra Ref
- Connections:
- $5 computer USB from Nuc
- Audition setup: Very kind visit from Robert Do
- Impressions
- Imagine solid state with a hint of tubes
- Linear and quick
- A tick muddled on quick transients
- Slightly less musical on processed and EDM than dCS
- Other:
- Near entry level DAC for Aries Cerat that held up to the dCS flagship. Wish I had more time with it!
- Changed the power cord from Transparent Opus to Inakustik reference silver and it resolved as well as the dCS
SW1X DAC 1
- Connections:
- Coax from my upstairs bedroom subwoofer went from Upsampler as passthrough to DAC
- Audition setup: Sent from distributor for audition
- Impressions
- Wonderful tube sound
- Did not seem to have the soundstage like the Lampi
- Struggled on transient and complex sections compared to the dCS
- Very smooth
- Lower mid balanced
- Other:
- This was a somewhat unfair comparison. The cable was an Amazon Basics subwoofer coax passing through other components.
- I do not feel entirely comfortable with this set of notes given the cobbled together setup
MSB Select II
- Connections:
- Roon Nuc -> Shunyata Omega USB t-> ProISL
- Audition setup: Purchased used for demo
- Impressions
- Body and density!
- Balanced across the spectrum
- Linearity to match anything
- Has every bit the detail of the dCS
- No harshness anywhere
- Has a width and depth of soundstage that is great
- Want for a tick more dynamic slam
- One of only two DACs that matched or bettered the dCS on all tracks played
- Other:
- I am keeping the MSB!
Summary: I only auditioned one DAC that I just did not like. Out of respect I have omitted it. I could have lived with any of the above DACs. The MSB and the Wadax were uniquely great at everything I played. The dCS is awesome with processed music and classical. The Lampizator continues to be curious to me as it was literally magical that first day! I am admittedly impatient and a bit compulsive - I maybe cut the cord too quick. I was close to buying the Wadax but the MSB was so very good that I just could not rationalize the price delta. In other words, price was somewhat always in the mix. But, I was ready to buy any of these and if the Wadax had been noticeably stronger I would have bought it. I wish I could have A|B'd it to the MSB and even the Lampi. But, when I heard the MSB I felt it sounded as good from memory as anything and that was it.
(...) You are only able to set filter settings for a format when that format is present.
Transparent XL clock and Transparent ethernetYes, but then the setting is kept for this format. After you set them you can save the chosen configuration, in order to keep them available anytime if you want to carry further experiments.
BTW, what were the clock and digital cable in the APEX?
Do you have a link for a comment of Emile regarding Apex?Emile is very proud of his Extreme server when used with the APEX and has very good reasons for it!
Great work. Being a biased happy Vivaldi APEX owner I only regret that you have not listened to the dCS using the Taiko Audio Extreme server or using a quality router. It would remove some of your objections, particularly in the vocals and decays. Can I ask what were the clock cables?
Indeed, on the Rossini APEX here the upper range vocals are smooth and not harsh at all even without the Taiko Extreme. In fact I would go as far as saying the vocals are a standout here.
I suspect you are still in break-in phase. I am about 180 hours in on the APEX break-in and it is still getting better. I don't hear the issues you list in points #2 and #3 above.INTRODUCTION
Over the last several months I have had the honor and the pleasure of accompanying pk_LA on what likely is the most extensive audition survey of top-of-the-line DACs ever conducted. The survey was conducted using pk_LA's new system consisting of the Wilson Audio Alexx V, the Boulder 3010 line stage pre-amplifier and the Boulder 3060 stereo amplifier, and Transparent Audio Opus Generation 6 cables.
COMPARISONS
LAMPIZATOR HORIZON VERSUS DCS VIVALDI APEX — FIRST SESSION
pk_LA began by playing a vocal track I had never heard before. He did not alert me as to which DAC we were listening. We listened to the track all of the way through. Then he played it again, on the other DAC. Within 60 seconds I said I believed that we now were listening to the Horizon. He told me I was correct.
pk_LA made many track selections over the course of the evening. I selected:
"Landslide" by Fleetwood Mac on Fleetwood Mac
"Witness" by Sarah MacLachlan on Surfacing
"Hallelujah" by Jeff Buckley on Grace
"Hotel California" by The Eagles (live version)
"Walk on the Wild Side" by Suzanne Vega on An Evening of New York Songs and Stories
"I've Got the Music In Me" by Thelma Houston on I've Got the Music In Me
My initial impressions of the Horizon versus the Apex:
1) I heard a harmonic richness and instrumental decay on the Horizon which was truncated on the Apex.
2) I heard on the Apex what I sensitively perceive as a slight digital dryness and sterile menthol sonic quality, and leading edge sharpness, which has always been my personal tell-tale sign of digital that I do not personally care for.
3) I feel the perceived frequency response of the Apex is centered in the upper midrange to treble, whereas I feel the perceived frequency response of the Horizon is centered in the mid-range (like how I perceive good analog playback).
4) I heard greater depth and dimensionality from the Horizon. The Apex sounded a bit "flatter" in comparison.
5) On each track that I selected and with which I am very familiar the Horizon presented the music in a way that reminded me of vinyl. The music sounded "right"; it sounded the way I am accustomed to these very familiar tracks sounding.
The first time I ever really relaxed listening to digital was on audioquattr's system in the Netherlands with the Taiko Audio SGM Extreme feeding a Lampizator Pacific. I enjoyed listening to the Horizon at Steve's during the Horizon debut. I enjoyed listening to the Horizon at pk_LA's last night. I conclude that if I have to listen to digital the Lampizator DACs simply work for me.
The dCS components are, to my personal aesthetic, beautiful and contemporary, and they look like they are machined out of blocks of aluminum. The Horizon is the best-looking Lampizator thus far, but, with its neon tube numerical display, it still looks reminiscent of Russian laboratory equipment from the 1950s.
LAMPIZATOR HORIZON VERSUS DCS VIVALDI APEX — SECOND SESSION
I returned to pk_LA's house for a re-match of Lampizator Horizon versus dCS Apex. On a track I did not know I failed to identify correctly to which DAC we were listening two out of three times.
It took a track I have heard hundreds of times ("Song of Bernadette" by Jennifer Warnes on Famous Blue Raincoat) to be able to tell the DACs apart.
pk_LA reported to me during the week prior to this second session the varying sound quality from the Horizon as the Horizon broke in since my last visit. Did the Lampizator change or did the dCS change?
Brian Berdan believes that, because the Vivaldi stack pk_LA is auditioning was just upgraded with the Apex circuit board, the Apex circuit board needed breaking in. This is a plausible theory. All I know is that the canyon-like gap in sonic attractiveness I heard between the Horizon and the Apex the prior week narrowed very considerably. If I had to quantify it I would say the gap has narrowed by at least 75%.
I still hear directionally the impressions I reported originally, but the amplitude is much lower. I still hear the Horizon as being more resonant and harmonically rich, but by a much smaller extent. I still hear the Apex as having more treble energy, and the Horizon as being slightly more midrange-focused (which I find more natural and more "correct"). I still hear the Apex as being slightly drier-sounding than the Horizon, and with leading edge transients I find unnaturally sharp.
The only thing I prefer about the the Apex over the Horizon is the resolving power of the Apex. All information and detail is “dug” out of those zeros and ones by the Apex.
I still easily prefer overall the Horizon over the Apex, but the gaps in what I prefer about the Horizon have narrowed very considerably. And the fact that only a week later I had to dig deep and use a track I am extremely familiar just to tell the DACs apart is puzzling — and telling.
PS: Alcohol consumption was identical during both listening sessions.
INFIGO METHOD 4 VERSUS DCS VIVALDI APEX
The Infigo Audio Method 4 DAC (MSRP $35,000) is designed by Hans Looman, a Dutchie from Delft, The Netherlands, who now lives in Canada. Hans is the CEO and Founder of Infigo Audio. Hans was very straightforward, very low-key and very knowledgeable about digital audio circuit design.
On a couple of the tracks with which I was unfamiliar I could not tell which DAC was which. But on familiar tracks I could determine which was the Method 4 and which was the Apex.
Overall I found the Method 4 to be smoother and slightly warmer and more analog-sounding than the Apex. I found the Method 4 to offer generally slightly greater decay and more harmonic resonance than the Apex.
On Jeff Buckley's "Hallelujah" on Grace the attention-grabbing guitar pluck in the beginning of the song sounded slightly more edgy on the Apex. On the Method 4 the guitar pluck sounded like I am accustomed to it sounding. It sounded more organic and golden, rather than slightly less natural and silvery.
The last track we used to compare the DACs showed us something interesting. This particular track had a dance vibe. When we played it on the Infigo we felt we had a bit of a drive literally to get up and dance. Playing this track on the dCS I had no such feeling to get into, or to connect with, the music. The dCS made this lively track sound a bit clinical and unengaging.
The dCS Vivaldi Apex is the champion of resolution, detail, dynamics, and low-frequency punch. To my ears it is the sound of the Boulder electronics in the functionality of a DAC.
The Lampizator Horizon thus far remains my favorite DAC in this on-going audition and comparison process. Interestingly I preferred the Method 4 over the Nagra HD even though the Nagra HD has a tube amplification stage. To my ears the Method 4 sounded a touch more natural and tube-like (this, for me, is a compliment) than did the Nagra.
SW1X DAC III SPECIAL VERSUS DCS VIVALDI APEX
In contrast to the Infigo which I felt was only slightly less resolving than the Apex, the
SW1X DAC III Special was conspicuously less resolving than the Apex. The SW1X was richer-sounding and more natural-sounding and less "digital"-sounding than the Apex, but I felt the SW1X sacrificed too much in resolution to achieve its richer, warmer, smooth sound.
The Infigo Method 4 sounded slightly richer and more natural and less digital than the Apex as well (as reported above) (indeed, a little bit tube-like in tone and density but without the soundstage dimensionality of tubes) but without sacrificing as much in resolution as the SW1X appears to sacrifice.
With the SW1X it seemed like some subtle details and a sense of air around singers and ambient cues were wholly missing in comparison to the highly-resolving dCS.
