Hi Ted, roomwise, do the angled ceilings help or hurt? And how did you deal with the little alcove behind the speakers, which has 2 storage shelves of music and houses the amps?
Obviously you are getting great sound already, but is there more to be done for the room or are you set?
Im biamping.... That ok ? or should I go thru the whole ac measuring of a test tone at speaker outputs of both? Cross over of the speaker is 220hz , so thought to do a 4th order high pass at 100hz or so for the mids/treble and a low pass with 4th order at about 500hz ?
Ted,
gorgeous room and wonderful system and elegant room environment. love the great pictures. it has to sound spectacular.
I'm another one who loves the space behind my speakers. my room is 21' x 29' x 11', and an oval shape. the front baffles of my main towers (a 2 tower speaker system) are 9'6" from the wall behind, and 109" tweeter to tweeter, I sit in the near field at 92" tweeter to ear. so I'm 17" into the 'near field'. my chair is almost exactly in the dead center of my symmetric room.......so half the room is behind where I sit.
btw; the term 'near field' has to do with the listening position relative to the tweeter spread. if your ears are closer than the distance between the tweeters then you are in the near field. it's not a distance issue but a relationship issue. 'far field' obviously being where you sit farther from the tweeters than the distance between them. and significantly; to sit in the near field typically requires a well treated and balanced room since otherwise the reflective energy will drive you back into the far field.....and if that is happening when you move up into the near field don't blame your speakers......it's your room treatments or lack thereof.
again; congrats and a very excellent system there.
Ted....a swoon worthy system! Have enjoyed following along with this thread.
Gentlemen, with the Spirits, does the cross-over sit outside the speakers as a separate box? Or is it an option to have it that way? (I swear I remember reading that in the promotional literature.)
Does anyone understand the pros and cons of this approach?
I have spoken to my own speaker designer of my EA MM7's about this who uses the MM7 crossover for the MM3 'Exact' in an outboard design, and at the L.A. Show in June he introduced a new high performace small footprint speaker system with a large outboard crossover. from those conversations.....
cons for this approach would be three;
-another enclosure increases costs, raises the retail price.
-crossover is farther from the drivers, a theoretical 'only' difference, but a difference.
-needs more floor space, another box to ship and handle.
pros include....
---allows for a more unrestricted cabinet design for best performance.
---allows unlimited space for a large crossover regardless of the cabinet size (in the new EA speaker, this was significant after he saw how the large crossover from the MM7's transformed the MM3's. the new crossover for the new speaker is a lower spec version of that same MM7 crossover).
---allows for clean sheet thinking about crossover possibilities.
---speaker cabinets are not idea places for circuits; they are not places where heat dissipates easily and they vibrate, outboard crossover cabinets can even have exotic resonance treatments applied.
---crossover upgrades much more real world possible (customer can fairly reasonably ship back crossovers compared to speakers. Speakers get more easily damaged in shipping, crossovers are like electronics.).
---when a speaker family is like the Giya's, their 'vibe' is their visual impact to some degree, this allows for that 'vibe' to not restrict performance.
Hi caesar. Yes the Spirits have an outboard cross over hard wired to each speaker with about an 18" cord. (...)
Speaking to Dickie and the team, the primary driver to move the crossover outboard was to free up some cabinet space for the larger bass units and to bring the overall cabinet height down, which in turn brings the tweeter to approximate ear level.
I asked about colours for the crossover and they can be matched to the speaker if requested.
Just reminded me about my plans to get a CAT preamp... congratulations for this fantastic set-up!
