This is an attempt at humour ,right?Best to go with Dave's silver/gold Neotech blend and tweak to subjective taste with DSP. You can always add warmth in the digital domain, but you can't add transparency if it's hardware limited.
Keith.
I think following some of these builds with "use whatever's left for cables" isn't the best approach here as it underestimates the cost of cables that won't be a big bottleneck.
Keith.
And the very slight difference in conductivity affects the sound how exactly?No I'm serious. It's well known that silver is a better conductor than copper. And the PCOCC refining process make a measurably better conducting metal.
Keith
Try comparing cables ,unsighted, always revealing.Give it a try. If no difference is heard then perfect. Go out and buy a bulk roll of AC extension cord to use in your system. It will save you a pile of money, as well as your clients.
Keith.
Keith.
I believe Peter Walker used lawn mower cable ,he was a real engineer.
Keith
They certainly can sound different if you choose to alter the electrical parameters enough, but why would you want to?Why not. There's other areas that should be focused on first before cables that's for sure. But they do sound different from each other. Compare the DHlabs Q10 to the Neotech 3004. It's like having different speakers.
Does it measure better at the output of the device?
Tim
Cables are completely transparent, unless you choose to make them otherwise.
just buy something fit for purpose.
Keith.
Keith.
Silver is good for phono. If you don't like phono...
