Caesar,
I know what you want. Bass is the final frontier and it's really challenging to achieve in most systems. I agree, to some extent, with Lavigne. If I may paraphrase, he contends that bass incorporated as a complete system sounds better than simply tacking a pair of subs onto a 2 channel full range system.
Where I disagree, has to do with complexity and who is best suited to integrate the bass into system. I don't think it's even worthwhile to try a pair of subs or more unless one is willing to use a crossover, some EQ and delay. Subs aren't different from any other driver in a speaker. Speaker manufacturers spend a lot effort EQing their design with analog parts to get all the drivers to cohere. The sub and bottom end of the full ranger need a crossover for the bass to sound natural. Otherwise a compromise must be struck. The specifics will depend on the system, but there will be a less than desirable outcome without these basic elements.
Also remember that very low frequencies don't always sound best in the same position as the R/L speakers. That's why you often times see subs up against a frontwall or a little further away from the seated position as the R/L speakers. These setups with speakers at various distances from listening position DO cause audible incoherence in group delay between the different speakers. This group delay difference really cannot be corrected with an analog crossover. Analog crossovers simply can't delay a signal with enough time or precision to best achieve smooth time domain behavior. IME, the best sub integration involves software and a DAC with more than 2 outs.
I know you want a simple solution. I think the best option for your situation would be a Revel Rhythm2. Larry greenhill wrote a review in this month's Stereophile. It's advantage over other subs is that it has a built in crossover with an excellent AtoD so that delay, crossover and EQ could be dialed in for the main speakers and sub. It's an interesting product for someone like you who probably doesn't want a media server but wants a much more sophisticated method of incorporating an external sub. You should check out the review. It's not online yet so you need a hard copy for 2/15 Stereophile.
Michael.
Michael.
