FWIW - my continuing series on the above topics, and more:
http://http://www.psaudio.com/article/subwoofery-trick-or-treat/
http://www.psaudio.com/article/trick-or-treat/
http://www.psaudio.com/article/wait-a-minute/
http://www.psaudio.com/article/smooth-operator/
I believe in measurements from DSP room correction systems (EQuing) on top of acoustic room calibration when it comes to integrating subwoofers with the main satellite channel speakers. A good EQ system can do audio magic with inexpensive quality subwoofers, IMO. ...Dirac Live, ...the latest Audyssey MultEQ XT32 iteration with manual adjustment from your laptop...
• http://www.audiovero.de/en/
One of the biggest hurdles I see with 2 channel enthusiasts is the resistance to measurements with a microphone. I would disagree that DSP is required for great performance. It is yet another tool. While fine tuning, exact spectral balance, and subjective preferences aren't immediately clear with a microphone, it is a wonderful and now very inexpensive tool to diagnose offensive bass issues and give direction toward solutions. I've mentioned it before, but again I'll reiterate that the method of achieving relatively even delivery of the entire bass range is much less important than the achievement. Excellent results can be had in some rooms simply through placement and treatments. Many do not have the placement flexibility or spaces that make this plausible, but there is no reason for those reluctant to employ DSP correction to turn their nose up at the information and insight a few measurements can provide.
I don't think that it's a matter of turning noses up Mark, IME taking measurements without having proper understanding of the fundamentals is only an exercise in futility. Most audiophiles and even many so called "experts" lack this basic knowledge. What's the value of sticking a microphone in a chair and getting a bunch of readings that are most likely erroneous? If anything they can lead the person further down the rabbit hole.
david
The best world music concert halls are designed from calculated measurements. (...)
david
david
I think measurements have a value and I've certainly gained from seeing them for my room (thank you Gary). but being a slave to or having blind faith in measurements is a mistake.
measurements do allow you to attack gross FR problems with the best tools. and 'seat of the pants' 'by ear' will likely never get you close to a solution. however; when things are in the green 'ok' zone then I think ears are better for fine tuning. music is a dynamic changing sort of thing and the best musical truth is a subjective thing.
I do accept that a speaker designer who regularly uses measurements to set up their own speakers might be the exception to my viewpoint (it takes lots of experience to properly take and apply measurements). OTOH it's also possible that their knowledge gets in the way sometimes.
just my own opinion, YMMV, and all that stuff.
Unfortunately we never had any direct evidence of the cases of success. The fortunate owners of SOTA rooms do not dare to post the measurements taken during their creation and current measurements.
IMHO measurements can be nice to help diagnostics and control, but not to correct problems.
BTW, IMHO a single unique measurement of the frequency response at the listening position, as shown in 99% of forum posts, can be highly misleading. Surely YMMV.
I disagree with gross FR problems; if you can't hear the gross obvious then you need someone who does. 2nd, measurements don't give you the tools to do anything, at best they can point to a potential problem, tackling it is an entirely separate deal.
david
It's not easy even for experienced listeners and measurements to identify *some* gross problems. The measurements I took of Mike's room only began to point out potential areas to address in very broad strokes and let alone identify specific potential problems. They did not show that he had one of four woofers wired out of phase, and I have to admit that I certainly did not hear that!! However, that may have been masked by other room problems as many other experienced listeners had gone through his room without noticing.
Bob,
We will disagree on this one. To speed things I will just quote Wikipedia:
Musikverein the "Great Hall" (Großer Saal) due to its highly regarded acoustics is considered one of the finest concert halls in the world, along with Berlin's Konzerthaus, the Concertgebouw in Amsterdam, and Boston's Symphony Hall.[1] None of these halls was built in the modern era with the application of acoustics science and all share a long, tall, and narrow shoebox shape.
I think that we can design great rooms and great subwoofers without taking measurements. But in general, before, or after, sound is a science still full of mysteries...
Bob, concert halls fall in a different acoustic domain than home listening spaces. They are considered "large" which in technical terms means their transition frequency where you get modal response is down to 20 Hz or even lower. In typical listening spaces in our homes, we are at 200 to 300 Hz. Meaning below that, we have lots of peaks and valleys which are far more easily identified with measurements than ear.Hi Mark,
Some music concert halls built over hundred years ago are some of the most preferred ones acoustically in the world; I agreed with Francisco (microstrip).
