Thus my confusion, rbbert. Has anyone (and, in particular, Ethan & Tim, since Tom just replied) posted perfect reproduction is attainable?
I guess this is the passage of interest by Ethan. This comes to down to the difference in philosophy of the types of audio enthusiasts: the majority accept that audible and disturbing distortion emerges from the speaker cones -- because of deficiencies earlier in the chain -- so the job of making the sound appear credible then requires a great deal of manipulation of the listening environment to minimise the impact of those abberations; others, like themself, attempt to reduce those "distortions" exiting the driver to the lowest subjectively audible level.Again, this has nothing to do with the fidelity of the gear, and I wish people would stop inserting this red herring into a discussion of audible transparency and differences between audio devices. It's another issue entirely, having more to do with loudspeakers, room acoustics, and mic technique than audio fidelity.
BTW, how does one measure a microphone, or a speaker? Does anyone else see a tautology here?
What would be really interesting, is sending the digital through a "best" D/A -> A/D and comparing that using DiffMaker ...Well yeah, but this had been resampled from 24/96 to 16/44.1, then back up again. So the two files were not bit-identical.
Edit: Once you do the resampling along with conversion from 24 to 16 bits, that resolution is lost forever.
But notice no mention is made of distortion: this is a hard one to crack, a whole lot of technique would have to go into getting something like valid measurements of this ...Microphones can be measured/calibrated by sending to NIST in the U.S. or to NPL in the U.K. and are calibrated either by Reciprocity, which is the standard, Comparison or Pistonphone.
Frank
NOBODY in the world has a two channel stereo system that replicates a live performance. About as clear as I can get since you asked again!
I am not implying nothing but whats in my signature space below and would be glad to debate anyone line by line
Tom
That's why I quoted the word: I would defer to your estimation of the very best combination of units, or single unit, that did the job when chained in an optimum configuration ...What would you define "best"? I've never seen/heard a converter that had the best A/D AND D/A. The best A/D are the Grimm AD1 and the MSB Studio ADC and the best D/A is the MPS-5 or the dCS Scarlatti
This gives you a pretty good rundown: http://en.wikipedia.org/wiki/Measurement_microphone_calibrationBut what is the mechanism for the measurement, i.e. how are signals generated for the microphone to respond in order for its characteristics (frequency response, distortion, polar pattern, etc) to be measured?
Frank
Aye, there's the rub!! Many a slip twixt ...Now what cable should I use!!
Frank
Hi rbbert.And both Tim and Ethan have stated (see previous posts and quotes) that the A>D>A chain is perfect. Their arguments are unconvincing, to say the least, and I also haven't seen an answer to my question about Tim's self-contradictory post about "voicing" of DACs.
But the question that is unanswered (and critical, IMHO) is how is the original standard microphone itself calibrated?
The technique provides a measurement of the sensitivity of a microphone without the need for comparison with another previously calibrated microphone, and is instead traceable to reference electrical quantities such as volts and ohms, as well as length, mass and time.
What a train wreck.
What a train wreck.
