First.........Now, you are an audio manufacturer, and thats good. So, if music is not "near" sinewaves, care to educate the entire professional audio community on what it is?
Second.....what test out there is better than a null test for audio? Have you thought this through mate?
Tom
Well the best all-in-one converter with AD/DA capabilities is the Digital Audio Denmark AX24. Give me a hi-rez file and I'll just make a loop out and in and capture the signal.
Now what cable should I use!!![]()
Have a closer re-read of the reciprocity calibration section. I've repeated part of it below.
Hi rbbert.
We'll have to let them speak for themselves. Perfect is such an absolute term. I'd be surprised if, when either of them return to this thread, either one states any DAC is perfect. Audibly indistinguishable from one another under a proper scientific test, probably.
...DACs used to accurately convert digital audio to an analog signal? I'm not sure there is a lot of work left to be done...
Tim
... But that alone proves to me that one A/D/A pass can be truly transparent...
--Ethan
I've quoted both of those before just recently. "perfect" may be a word I chose for its shock value, but is it in fact very different from "truly transparent" or "not sure there is a lot of work to be done"?
Bruce,
What digital format are you referring to you when you address sound quality of ADC and DAC converters?
In my opinion it is very different. Transparent is used in the context of systems, and existing technology. Can a good ADC/DAC can digitize an analog signal, then convert it back to analog "transparently" enough that sophisticated listeners, in blind tests, listening to high-end systems, can not distinguish between the the original signal and the converted one more often than they could guess? Yes. This has been demonstrated a few times.
Tim
Sensitivity, sure. How about frequency response, distortion, etc?
Sensitivity (in Volts per Pascal, where a Pascal is the unit of acoustic pressure), when measured over frequency, is the frequency response.
Distortion though, as Frank previously mentioned as well, is not covered by these techniques.
As I thought, Tim did not state that to which you ascribed to him. Mischaracterizations abound, emanating from the first post in this thread.Tim,
A reasonable response, thank you.
Nope. No one who is being intellectually honest is making that claim. This ties in to the next statement:A big problem I (and I suspect others here) have is that blind tests similar to those you reference also show that moderate bit-rate MP3s are indistinguishable from CD-quality audio, a claim that I don't think you wish to make (but I could be wrong).
There is virtually nothing in the OP's suspicions which is correct unless you believe in gross mischaracterizations and stereotypes. This was pointed out earlier in this thread. *Objectivists* don't listen to measurements and subjectivists don't ignore measurements, except at the lunatic fringe of each such characterization.It's interesting (but not surprising) that the OP's suspicions put forth at the beginning of the topic seem to have been shown to be correct.
Regrettably so. But hopefully here, at WBF, we can elevate our discussion of these kinds of matters with decorum and intellectual honesty.In my experience, the people whom you ascribe to the "lunatic fringes" of both extremes are far more common than you think.
(...) Also rubbish are claims that Tice clocks, Shakti stones, Hallographs, Frank Tchang resonators, and power cords make a difference. Small minority? Enough of them to sustain an industry, apparently.
So Ethan.... what is the "thermal noise over the audible band" of the MSB Studio ADC? Also... what is the "non" A-weighted measurements of the MSB Studio ADC. If you don't know.... don't respond. Besides, the graph spectrum shows the noise from 7.5k to 14.5k.. certainly within the "audible band".
