What turntables do you use? Pictures would be nice as well :-)
Another one is based on Verdier La Platine in Steve Dobbins plinth and two tonearm boards
Very nice! But is it basically a modified La Platine with a different plinth? So they hide the La Platine’s magnetic floating assembly below the surface of the plinth ?
I am considering getting a custom plinth for my La Platine, so any information would be appreciated
Thanks
Thanks
That is exactly correct. essentially the original La Platine “plinth” is just a support for the magnet assembly. Dobbins’s plinth is made of five different materials and is very heavy and inert.
It sits on Nordost Sort Fut
Reactions: thekong
Thank you for the reply!
Reactions: Petrat
This is the part I would like to hear @mtemur ’s comment on as he knows a lot about the Platine having gone through many and owning it
Reactions: mtemur
Reactions: AudioHR
I haven’t personally heard the Dobbins plinth, so I can’t comment on its performance, but it certainly looks promising.
The standard plinth on the Verdier turntable is made of HDF, which is a bit denser than MDF, and it’s reinforced by three steel plates. HDF is quite inert due to its high glue content, meaning it doesn’t resonate at specific frequencies like wood, but overall, it’s not an outstanding plinth. It works, but not exceptionally. The steel plates, however, significantly improve the HDF’s performance. They’re welded, painted, and when I tap the base, it’s dead silent. There’s also an elastomer layer between the steel and HDF for additional isolation.
The base includes three spring-elastomer-metal feet, which need to be carefully aligned to ensure they only contact the plinth through the elastomer layer. This setup is effective, but in my experience, plinths made from stiffer, harder materials like metal—especially when properly damped—deliver much better results.
If you’re thinking of upgrading your Verdier plinth, it’s also worth considering finding new springs for the feet or an alternative solution to accommodate any change in weight cause springs are tuned to original plinth. Keeping this in mind older stone based Verdier makes sense cause it has a lot of glue. Slate is also worth considering, though it’s notoriously difficult to work with since it breaks so easily.
Personally, I’m not planning to replace the plinth on my Verdier turntable at the moment. There are just too many variables to consider. Instead, I’m focusing on upgrading to an Artesania stand for all my equipment, which seems like a more practical improvement for now.
This is the rig we use to listen to mastering clients' test records (a surprising number don't have access to one) - and for my personal listening pleasure.
Nottingham Analogue Dais, (in pic) OL Illustrious, Dynavector DRTXV1S. The OL arm has just been upgraded to the Conqueror. This pic is to remind me of the as-was. Phono stage is the Soulution 520
Hi, did you try any other tonearms before settling on an OL arm?
Nice what speakers and amps are you using?
Hi mtemur,
I have a couple of questions for you regarding the La Platine. I read that the Callas modification kit for the La Platine offered a tighter tolerance bearing. I also understand that you have done a lot of W&F measurements on highend TTs and found the La Platine already had one of the best measurements among them.
While the Callas kit has been discontinued, I wonder if a tighter tolerance bearing is something worth pursuing! Would its benefit show up on W&F figures, or somewhere else?
As for the plinth, I am contemplating on one with two layers of aluminium and brass and with an elastomer layer in between. Do you have any advice?
Thanks !
Reactions: mtemur and Petrat
Most of the Callas upgrade kit can be done as a DIY project, but in my opinion, there’s nothing particularly special about it. A friend added the Callas upgrade to his Verdier, but it didn’t impress him as much as he had hoped.
According to Eric Verdier, the shaft diameter was changed in 2011 from 19.99mm to 20.01mm due to an update in the manufacturing process of the zamac bearing. My Verdier is a 2011 model, while my friend’s is from 2010. We ordered the new shaft and replaced the old one on his turntable. After some break-in time, the sound noticeably improved with the new shaft. There have been steady design improvements since the Verdier was first introduced in 1979.
Yes, the Verdier measures among the best. The key feature is the control-free DC motor. It doesn’t use an encoder or speed correction circuit—just a transformer, 5V regulator, and a capacitor. This allows the motor to run smoothly without constant interruptions from a control circuit. The downside is that you have to manually fine-tune the speed as the bearing heats up. I usually set the speed at the start of a listening session, and after 4 hours, it only drifts to 33.37 RPM. While this small change is imperceptible, constantly adjusting speed through a control circuit can increase wow and flutter, which becomes noticeable.
Other factors critical for minimizing wow and flutter include a balanced, high-mass platter (ideally magnetic or air-lifted), a bearing with tight tolerances, and lubricating oil with enough viscosity to create sufficient brake force or load on the motor. In addition to that for the Verdier, one of the most crucial things is properly centering the magnets inside their housings and centering the lower magnetic assembly with the bearing assembly.
There’s definitely a lot of trial and error involved with that process, but I’ve kept mine original, so I can’t say anything for certain. A friend of mine used a Kondo stone base, originally made for the Ginga, under his Verdier, and it turned out to be a great combination. Instead of replacing the plinth, I’d recommend adding a solid stand for better results.
Hope this helps!
Hi mtemur,
Thank you for the detailed reply, really appreciated it! I didn’t know about the spindle change started in 2011! Since I got my La Platine second hand, I have to check with Eric about the year it was made, and get the new spindle if necessary! Thank you again for this information!
Reactions: mtemur
Hi mtemur,
I believe Eric Verdier has officially announced a permanent closure of the company a few months ago
Reactions: thekong
Thank you for the information! Really sad news if it’s true! I have just checked their website but no announcement there yet, so I will try my luck to email him!
Please let us know if you got a response
Sad news, I have received the following automatic reply, originally in French, but google translated into English here:
This is an automatic message sent to you by Eric Verdier.
Dear Sir,
> The Verdier laboratories are permanently closed following the death of
> the owner-operator Mrs. Michelle Verdier, which occurred on December 20, 2023.
> I am not currently able to respond to requests for parts
> or repairs.
> Very cordially,
> Eric Verdier
  • Sad
Reactions: mtemur
Dear Sir,
> or repairs.
> Very cordially,
> Eric Verdier
Exactly, i got the same a few months back when i was trying to buy a spare motor from Eric.
They must have a stock of spare parts left i assume.
Well, let’s see if he returns my message later! I’ll also try to contact their local dealer to see if I can get the spindle through them.
Some good news, I have received a reply from the company which has purchased Verdier the company, and will continue the production! Here is the reply:
>We have got you inqiry by mr Eric verliert
We have purchased the company in mid 2024
We will now to continue the production
I have consulted with Mr verdier your question
Yes it is true that in 2011 there was a change in the bearing diameter
Yet this change is NOT able to upgrade older models
It would not fit and omprove the tolarances
If you have mire questions please let me know
Best regard
Heinz Lichtenegger
Audio Tuning Vertriebs GmbH / CEO
Pro-Ject Audio Systems / President
Musical Fidelity / President
Tel.: +43 664 240 1661
E-Mail: h.l@audiotuning.at
Vienna Office: Margaretenstraße 98
1050 Vienna / Austria
Headquarter: Wirtschaftspark A5, Analogweg 1
2130 Mistelbach / Austria <
That’s terrible news, Pro-Ject bought the company if I read correctly. It won’t take long to release magnetically levitated plastic turntables.
That’s not true. New, larger diameter shaft fits old models, maybe not all but certainly fits the 2010 model. I know cause I installed one and it was recommended me by Eric Verdier. Otherwise how would I know.
Reactions: AudioHR and Petrat
