You will miss a lot of potential but it’s your choice...I would preferably go with a low powered push pull amp for sure. How is the bass with your existing Coincidents?
Any reason why you you must have a 300B with the Devores. you might want to consider running them with a good 211
Lol, you are funny Keith...please tell us about your amp experience with Devore speakers. thanks
What speakers have you heard the Nagra on? Not saying you are wrong about it but seems quite an absolute statement about its snappiness. If you heard my JJ amp you would probably conclude the same thing with most speakers but put it on the right speakers and it has punch and dynamics. Many (but not all) SET are this way. Some SETs sound very powerful with a wide range of speakers.
You might look into the Luxman MQ-88uC amplifier. The Air Tight EL-34 amp would also be worth consideration.
Here's one last one- Audion PSET KT88 monos (and not expensive):
https://www.audion.co.uk/Mono blocks/Sterling Anniversary KT88 PSE.html
@bonzo75 Old thread here but a quick question - did you feel the bass performance was solid with the Air Tight 300b driving the O/96's?I compared airtight 300b and the el34. The latter was better on the Cessaro Wagner. The former was much superior on the O96
Thanks...how didn't I know this? ha...I will drop him a note.John DeVore uses the Air Tight 300B as his personal amp. I would ask him.
some PP or parallell SE 2A3 might do the trick, if one likes the intimacy of the lower power DHTs but need a little more balls
@essrand Thanks for following up. I was curious how that Nagra was working out for you.
A quick question about the MQ-300. I've heard many say that it produces fantastic extension on both ends of the range, but I was wondering if you feel it's at the expense at all of the magical midrange that 300B is known for. This amp is near the top of my list. I know John DeVore used it at the last DC show to demonstrate the O/Ref. I may ask John if he's spent time with the Luxman paired with the O/96. He recently gave me his thoughts on the Air Tight ATM-300R with O/96's which he strongly advocated.
