Home studios? You have statistics on how much of the music we consume comes from there and what percentage of them are produced at 16/44.1?
I have only anecdotes from email contacts. It's not data, so I have nothing much to offer here.
That's cool. Please show proper research and analysis as Bob has done.
The fact that we're having this discussion at all indicates I've provided sufficient information to debate. I'll continue adding to it.
Don't put up ultrasonics near clipping and say, "look, there is distortion."
The fact that it is near 0dBFS is irrelevant as digital shows the least noise and distortion near clipping. You're thinking in power-amplifier terms (and I think we can reasonably expect most people to have mastered their volume knob). This is a perfectly valid synthetic test signal for system analysis.
That is not how to advance the discussion. You may not have noticed but I am far, far closer to your position than the 192/24. But you make me uncomfortable in that type of tactic you are using and lack of proper and deep analysis. Please step back and realize that. If you can't have me be on your side, you have no prayer of having anyone else.
And yet that feels more like a threat than any offer of advice, Amir.
The belief I have is in analyzing the problem as Bob has done.
We can compute the perceptual levels of the system noise+distortion and compare that to threshold of hearing. I read that you don't know why that works.
No, I said that the analysis Bob presented looks correct on its face, but doesn't stand up based only on the details provided.
But if you had read Bob's other research papers, you would have seen that to be proper.
I have read Bob's other research papers and found them... overly tinged with the fantastic. I was worried about linking Coding2 at all because several others are severely problematic (and disagree with Coding2 for that matter). But I judged it was a good piece of writing and presented many of the same concepts very well, even if I disagreed with specifics, and had problems with the other papers.
But, I'll be a good sport, I'll go back and look.
Therefore, we have evidence that 16 bit channel even with dither is not transparent to our source relative to what we can hear.
No, you have a theory that experimentation didn't support.
Why was the article about 24/192? The only public statements from Neil Young/Jobs was along these lines:
http://allthingsd.com/20120131/neil-young-and-the-sound-of-music/?mod=googlenews
Fair question.
When Neil's group contacted me, the first thing they wanted to talk about was 24/192. I replied I probably wasn't the person they wanted to talk to, because I'm a skeptic on the subject. They replied that they didn't believe in high-res either, but they couldn't sell to audiophiles unless their product was high res. So then they wanted to know what other hooks could serve the same marketing purpose. We went back and forth on that a bit, also discussed FLAC, and the conversation eventually petered out.
When the Neil / Steve story hit apple insider, wired, etc, a significant amount of the commentary was about 24/192. Most of the justifications for absolutely needing high-res had the basics wrong. This was the real impetus, and I wrote an article. End of story.
Don't you think you are distorting his public views by making it about 24/192?
Not in the slightest.
And you can't show transparency at 16/44.1 unless you can counter Bob's analysis. So far, I have not seen you do that.
Analysis isn't data.
The data doesn't agree with his analysis that slightly more frequency extension is needed.
His analysis of bit depth states that 14 bits shaped is enough; the experimental data is generally on 16 bits shaped, but it shows 16 bits shaped is transparent.
All data agrees that 20 bits undithered is transparent, but I don't see any data demonstrating it's necessary.
We are not similarly situated. You have written an article with a sensational headline. That article, and its author, you, have been put up as a topic to be discussed.
_You_ put me up for discussion. I should think discussing me is off-topic.
So we are discussing it. Your credentials are to be evaluated against other people who have come up with different conclusions than yours.
Oh, so the correctness of my presentation is proportional somehow to my credentials? I assert it is not.
But here, for good or bad, you are the topic
That's solidly off limits in professional discourse. Knock it off right now.
And it is not like you are showing due respect. Just in that last post you claimed I didn't know what an interpolator was. It is like saying they don't make hamburgers at Burger King
I withdrew my statement, and said you were right. You're seriously trying to use that against me?
