You may remember I provided a lot of scientific papers highlighting the complexity of any testing including ABX that still suffers from AB order bias
ABX suffers from AB order bias?
Do tell!
I agree ORB, DBX should not be discussed on this thread - I just had to comment on the testing procedures used (I had specifically asked to listen first, measure later) & how I saw it!Tim just using yours as it is the last post on this subject in the thread.
Can I suggest we leave the JND, double-blind testing,etc to the many other threads we have on such discussions.
You may remember I provided a lot of scientific papers highlighting the complexity of any testing including ABX that still suffers from AB order bias, and other biases similar to more traditional JDN double blind testing methods used in science outside the audio community.
Not going to say anymore on that subject here as I feel it is not the right place and it has been discussed many times already, but I have provided a lot of information in the past forums on this, including how with perception differences becoming more difficult then the number of passes reduce....
None of this is really relevant to this thread anyway as the focus should be processes-functionality-algorithms-etc with the consideration from the studio all the way to the consumer DAC (or anywhere in between including aspect of chip-DAC embedded/external architecture)
Thanks
Orb
Unquestionably the best is DBT AB/X, when you don't even know what you're listening for, other than to identify whether X is A or B. Hard to expect anything then.
It's amusing that Monty can state that he can't cheat by using ABX when in fact he's already cheated by looking at the measurements. Not truly blind now is it?
Here's our previous exchange on this :This is completely wrong, you're mocking me when you're wrong, and I'm pretty much done taking you seriously.
To which you later replied:I know at least half of the people who did this test & know that they did not analyse the files first. I specifically asked you or Arny to listen first & look later. A bit like Ethan's reply - he subsequently wanted knowledge about the files & I asked why? SO you guys really don't trust your ears - even though you proclaim blind testing for others, you won't abide by this yourself?
Yes if you want to peek but as I said I & others trust our ears & don't tend to peek . This is hilarious, I ask you to do a blind test & you try to cheatThe file sizes make guessing easy in retrospect too.
Did not! I used the ABX tool.
For the record, every human cheats. That's what big powerful brains are for. That's why the tools that don't let you cheat are useful.
Don't know what you're talking about, sorry??If you're wrong on ten points and right on two, the two don't make up for the ten. Why all the self-congratulation for failing to explain anything? You stopped testing when you got a result you didn't like. Debating the other points doesn't even matter when you're only willing to discuss the points where you think you're right.
I had no clue what was going on before I heard the tracks and that the differences were really obvious immediately, I replayed them a few times but really I only needed a first play to hear the differences - John either cheated royally or the differences are easily audible with a good system!
Here;s our previosus exchange on this :To which you later replied:
No mention here of not peeking at measurements first - your statement is that the ABX tool stops all cheating![]()
Has John proven that he can hear 0.2 dB ripple in an ABX test? Not that this can be proven across the Atlantic ocean. But has he even claimed he can hear that reliably?
--Ethan
Nobody's talking about rigging anything - we're talking about psychology & the traps of biasing. Sighted tests can be a source of bias, as can expectation bias (whether due to pre-knowledge of measurements or otherwise). The fact that you would do measurements before listening does say a lot about your approach. I specifically asked that listening be done first!! Measurements gave you a lot more information about the files than I provided so it doesn't equate to the pre-knowledge you already gleaned from me! You do remember the example I gave of a well known audio manufacturer who ran a test saying that it was a test of mains cables in audio. One of the participants was a staunch anti-cable guy & he found no differences in the tests whereas everybody else 100% heard differences. What the tester actually had done was reverse the polarity of the speaker cable during the tests. So you can see how strong expectation bias can be! I doubt it has anything to do with rigging the test.Spelling out the obvious: ABX and ABX-like tests stop any chance of rigging a positive result during the test. It removes the expectation bias in the given sample set during a test. It does not, and cannot, prevent rigging a null result.
Yes, it added information that was very relevant to what could/should be audible & this is a biasing factor. Unless expectation bias has been accounted for & eliminated then why would null results be of value in a DBT?It cannot remove all foreknowledge; you told us ahead of time what the samples were; that bias existed already. All you didn't tell us was which samples were which, and all that looking did was confirm: A) you weren't a liar and B) which samples were the original, 20 sample offset, and 60 sample offset. I had already assumed A, and the ABX tool removed the bias of B. So looking added no new bias.
Still don't know where you are going with this without examples but let's not go down that road!You're not being methodical, so being right occasionally... or even mostly... on the singleton points does not prove your assertions.
If these discussions happened during the Reformation, heads would roll!![]()
Yes same bits, i.e bit-perfect therefore no manipulation of bits. If we get into this area it will go all per-shaped so either a different thread or have a read of the existing bits are bits threads already on this forum.jkeny,
-- the digital bits jplay is sending to the hardware are different from the digital bits foobar is sending? Is it doing additional signal processing?
-- Linux is what you make it. I hope that statement is sufficiently vague, damning, and inspiring at the same time. It is the Bill Belichick of operating systems.
This requires quoting
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
