I don’t have a pair of those but I know a pair for sale if you are interested.Thank you for letting us know. In this case, may I give your Concero 65s a good home?
Ron, I thought you play back these videos over your main system via streaming? How does this one sound on that compared to your idea of how a violin sounds at Disney Hall for instance? I agree the violin does not sound bright and screechy from Ked's video when I listen over computer speakers.
This is stated correctly. Just because the sound of a particular system is not somebody's personal cup of tea, or does not sound like his/her system at home, does not make that particular system bad or wrong or unnatural.
Carlos, please try to understand this simple point.
Can you please provide the names of the recordings you recorded? I am curious to try them at home if possibleIf you listen to the two videos of my systems that I posted and then go back and listen to Bonzo’s videos, the differences in texture and the interplay of the musical voices in the sound is pretty apparent. Shockingly so.
No, I will not record those songs. Bob has a phone and recording devices. If he thinks that Bonzo’s videos mischaracterized the sound of these very expensive systems then he can record my songs on his Diesis/Kondo system or on any other of his finest sounding systems to showcase the distinguished sound of his very expensive systems.
And you don’t think at least some of it is due to the recordings? Also, aren’t you “remastering” yours? I would propose that until you play those exact recordings back on your systems without manipulation, then the experiment is inconclusive.Ron, I have close to 40 working systems. I get the simple point, that they all sound different but I also discern that some are more musical, articulate, resolving, powerful, extended, enchanting, immersive than others. Get the picture yet?
in other words, no one has any recording/media reference to judge his system by, the WAAR tweaked recording reference is unique to Carlos. so we simply judge video to video to judge system to system. preferences. what might the differences tell us? open for debate. not judging.The recording on my WAAR system with the remastering process is:
Shostakovich 8th Symphony -- Third Movement - The Battle for Stalingrad
The recording on one of my DHT/SET systems:
The theme for Succession
Brad this was not about comparing recordings, mine versus Bonzo’s. This was about the sound of the systems. The Remastering process is part of the sound of my WAAR system. My DHT/SET has no remastering process implemented. I assume that you telling me to not use HQPLAYER would be the equivalent to me telling Rhapsody not to use the Kondo Gaia or the Vyger Atlantis. The source is part of the sound of the system. The only thing that needs to be evaluated is the resultant sound. I don’t put restrictions on anyone and I don’t want anyone to restrict me on what I can do or should not do. What I have presented is the sound of my systems as they sound today. Nothing more, nothing less. What Bonzo intended to present with the videos is the sound of the different Diesis/Kondo system configurations.
without a reference media as a basis, personally i don't think much can be determined.
Oh but Carlos it is ALWAYS to some degree about the recordings…Inferior recordings can make a system sound far worse than it is. That being said, after going back and relistening to them there is a sameness of tone and perspective across the recordings of that system, that would unlikely be the same normally for all three different recordings.The recording on my WAAR system with the remastering process is:
i want to relisten to your recordings because on first listen I was not convinced by the DHT SET recording…it sounded strained in parts. The other one with the big Wisdom speakers was quite good.
Finally, a bit more info on the recordings please, which label, which conductor, which year, which orchestra as there are at least dozens of recordings of the Shostakovich and many are quite poor.
No but you should use the same music file or LP or tape etc. Everything else you mentioned is part of the system that you are trying to compare to another system.So for a comparison to be valid we must use the same cables, source, speakers, amplifiers. You are missing the point, what is presented is the resultant sound. The Remastering process is used to tailor the overall system presentation. What is presented in the video is the sound of my system.
Isn’t your equipment and system configuration unique to you?
By conceding that my Remastering process is that most powerful way to influence the resulting sound of a system you have proven my point, that there is a Smarter Way to approach system building. Thanks
The remastering is done in HQPlayer?Brad, the Remastering process is not applied to the recording but to the system. It may seem like semantics but if you were to apply those remastering setting to recording alone it would sound awful. Those changes were done to address the overall system presentation. Lucky for you, I have a video of the WAAR system with and without the Remastering process:
I think the sound of this violin is consonant with my idea of how a violin sounds at Walt Disney Concert Hall.
Ked, just a comment to say I enjoyed your DFW Rhapsody report. Most noticeable to me is that your writing skills have developed in parallel with your ability to describe what you heard in a meaningful way. Nice work!
Ron, this is quite a powerful statement about a system video recorded by an iPhone. The result is also a digitized version of the analog LP. You stated earlier something like that you would not be able to ascertain much from hearing an LP vs. digital file over a YouTube video (if I understand your earlier comment). That this YouTube system video sounds "consonant" with your idea of how an actual violin sounds, and I think you said over your iPhone speakers, that is quite something.
I presume Kedar feels the videos are representative of what he heard from the actual listening seat.
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
